really Loud wierd noise like revving
Old Jul 30, 2012 | 06:38 PM
SarahSTAR401's Avatar
So lately here and there my 2000 acura TL has been having some issues.
Sometimes mostly while trying to accelerate i will be stepping on the gas then suddenly the pedal starts vibrating and the car makes this awful revving type noise and it will last until i have to pull over and shut the car off. It doesnt cause any RPM jump and i can still accelerate. It also doesnt cause overheating or anything like that. but what could this possibly be. As soon as i shut off car and turn back on it stops.
Old Jul 30, 2012 | 10:45 PM
h23nutcase's Avatar
6th Gear
Coil on the plug is dying.
Old Jul 31, 2012 | 07:00 AM
Okay how do i figure out which one it is?
Old Aug 1, 2012 | 09:56 AM
01tl4tl's Avatar
get to parts store for code reading'
it may say multi cyl misfire--thats one coil bad
see threads on testing by removing power to coil and watch for rpm change
no change is bad coil
reset ecu by pulling clock fuse for a minute to clear all codes after coil install
drive and reck codes
Old Aug 8, 2012 | 06:55 PM
So the noise was actually because my ac compressor was fried. Changed the ac compressor and no no more noises!
Old Aug 8, 2012 | 08:40 PM
rockstar143's Avatar
but you also have a CEL for a bad coil pack? I saw your other thread...
Old Aug 9, 2012 | 01:53 PM
Teah but that shaking and stuff didnt happen until two days after i fixed issue one and the check engine light wasnt bringing up that code.
Old Aug 10, 2012 | 10:16 AM
01tl4tl's Avatar
either a wire got knocked during ac repair or you have a bad coil,,common problem
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
