Really Confusing Headlight Issue!!!
Old Nov 2, 2012 | 10:10 PM
acuratlforever12's Avatar
6th Gear
I continue to have little issues here and there with my '03 TL.
This might have been answered already but most threads seem to confuse me even more....
Earlier today, the right headlight (low beam) turned pink/purple then completely died.
I didn't want to buy those expensive bulbs without fully checking things, so I moved the right headlight bulb to the left and the left one to the right.
When I turned the headlights on, the right side still had an issue. It started out with pink/purple and died after a few minutes.
What exactly is causing this issue? If something needs to be replaced, is it fairly simple process? Lastly, how much would it cost?
Thanks a bunch guys!!!
Old Nov 2, 2012 | 10:28 PM
victus1's Avatar
Ahhh...it seems that your right ballast is destroying your bulbs. You have a faulty ballast/ignitor combo. You need to buy new ballasts. Not a difficult job. You need to remove the bumper to remove the headlights and ballasts. Search the forums here for instructions.
Old Nov 3, 2012 | 12:05 AM
3.2TLc's Avatar
You may want to consider updating the old ignitor/ballast with the newer water resistant kits available from www.hidextra.com at considerable cost savings over original parts.
Old Nov 4, 2012 | 01:47 AM
01tl4tl's Avatar
pink purple at startup is the bulbs age death warning
may as well replace the system with modern parts for only 59$ www.hidextra.com
get the 5000k bulbs
find coupons online for 10% discount!
couple hour diy, basic electrical connection work,,a little looking and figuring it out
water gets inside the lens and drips out onto ballast- fries system
new parts are waterproof
tman570
Jun 11, 2019 07:56 AM
TLrascal
Aug 3, 2018 11:00 PM
wusty23jd
Sep 24, 2015 11:41 AM
acuraST
Sep 17, 2015 02:31 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
