Radio TL 2002
Old May 3, 2015 | 11:37 PM
Truedlamar's Avatar
6th Gear
Radio TL 2002
My radio has been out for about two or three months last time it was the fuse because my clock nor my radio or cigarette lighter worked now it's just the radio . I unhooked it and tested it too see if any power was going thru it which it was so idk what to do I hate not having music it really sucks thanks .
Old May 4, 2015 | 03:20 AM
01acls's Avatar
What fuse number was it last time and where?
Old May 4, 2015 | 03:50 AM
01acls's Avatar
Check drivers side fuse/relay box fuse #8 (7.5A) and passenger side fuse/relay box fuse #9 (20A) for a blown fuse?
Old May 4, 2015 | 06:13 AM
Truedlamar's Avatar
6th Gear
I changed the #9 fuse last time I checked it recently and it wasn't blown
Old May 4, 2015 | 06:14 AM
Truedlamar's Avatar
6th Gear
Sorry #9 passenger side
Old May 4, 2015 | 09:21 AM
01acls's Avatar
Did you check driver side #8? And #9 again to see if it's blown again?
Old May 4, 2015 | 12:06 PM
Truedlamar's Avatar
6th Gear
#9 is for the navigation for which I don't have . I changed and checked the fuses earlier this morning went back in the house came back out 30 mins later and then my check engine light was on . Took it to get the diagnostic test
My neutral safety switch has a short or needs to be replaced she also said because it's so close to the radio it could be why it's not on
Old May 4, 2015 | 03:35 PM
01acls's Avatar
I’m getting confusing information from you, #9 on passenger side is for radio and acc, not Navigation? #8 driver side is Navigation. Are you sure you’re checking the right fuses?
If you have power at the cigarette lighters then I would check for power at the back of the stereo.
You need to disconnect the plug that goes in the back of the radio, the larger of the 2 plugs if the one you need to test for power and ground
Unplug the harness from the radio (key off).
With the key on in #1 position (dash lights on but engine not running).
Check for power at the Orange, Red/White, and White/Green wires at the male connector.
Check for a good ground on the black wire at the male connector.
If these wires check out fine, then the radio is defective, send it out for repair or buy a replacement.
Old May 4, 2015 | 05:09 PM
Truedlamar's Avatar
6th Gear
That's what I meant about the two sorry but I will try that because the one on the driver side #8 does nothing
Old May 4, 2015 | 05:35 PM
01tl4tl's Avatar
If the Neutral safety switch fails= you cant get it out of Park gear,
without using the override switch next to shifter
If you blow fuses it probably has a bad ground in the line.
dirleton
Aug 6, 2024 08:19 PM
Puma Jim
20
Oct 20, 2016 11:59 AM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
