Question (with pics)
Today after going out of a drive I get home and decided to check my oil level and tranny fuild level. Now I noticed it was kind of high for the oil but at least a good color and didnt smell bad. I know its bad to have to much in there but this wont make much of a difference will it?
Now I bought my car used and according to the documents I have my tranny has about 20k on it. Now I never checked the fluid before because I figured its new how could it be bad? So I figured its over due for it and I pull it out and its WAY over the maximum mark. Not only that but its not red or brown but its green????? Does anyone at all know what this means?
Originally Posted by Luke7
Leprechauns replaced your tranny? Just kidding=I have no idea.
I've read other posts where the fluid can turn brownish over time.
Here's one example:
https://acurazine.com/forums/car-parts-sale-361/wtb-h-r-sport-springs-93045/
But I didn't find any mentions of green fluid.
You might want to just drain and fill the fluid so you know what's in there. (Don't flush the fluid since that's not recommended for the 2nd gen TLs.)
Bob
Here's one example:
Bob
Here's one example:
https://acurazine.com/forums/showthread.php?t=93045
Bob
Here's one example:
Bob
Originally Posted by Trackruner228
Yeah I knew not to do the flush its just I even tried searching google and other places and I got nothing. I was hoping someone here would have the same problem but I guess not.
At this point, I'd just drain and replace it. And you might not want to have that done at an Acura dealership so that they wouldn't deny warranty coverage of the transmission because of the green fluid.
Bob
Your oil level in the first pic is normal. Thats where it should be.
The 2nd pic cant really see much. How did you test the fluid? car running? car off? cold fluid? hot fluid? It makes a difference in the level. As for color? it shouldnt be green. Pinkish red to brown depending on how much its worn. May want to look into a drain fill and double check the level
As for the color what does make sense is im also positve its the orginal tranny fluid. It was replaced at 71k according to the recpeits and the acura dealers and I bought it at 83k so I figured it was fine because it was a brand new tranny (replaced 06/05) so thats why I dont get the green at all. I think this might explain when my car is shifting like crap. I have about 92K on it now so its a fairly new tranny so im going to see whats going on maybe look around.
It is a bit bizarre. I also couldn't turn up anything on it with Google.
Bob
Bob
DiamondJoeQuimby
09-10-2015 11:40 AM
