purge control
Old Aug 17, 2005 | 06:57 PM
zeek0666's Avatar
4th Gear
Question purge control
anyone having problems with a noisy purge control selonoid? mine seems too be ticking louder and louder.
Old Aug 18, 2005 | 08:32 AM
Dare_IL's Avatar
Need a WHAmbulance
Is that the same thing as a sphincter valve?
Old Aug 18, 2005 | 11:24 AM
fsttyms1's Avatar
its a fairly common problem with the TL (usually worse in the colder months). if you are under warranty see if you can get the dealer to replace it for you.
Old Aug 19, 2005 | 01:54 PM
zeek0666's Avatar
4th Gear
yes i am still under warranty. thanks for the info :
Old Aug 19, 2005 | 05:53 PM
sbuswell's Avatar
I need 2 more gears
what is a purge control selonoid? where is it and what does it do? also what noice would it make if there was a problem with it?
Old Aug 20, 2005 | 11:36 AM
brakejob's Avatar
:brakejob:
danger to manifold!
Old Aug 20, 2005 | 01:47 PM
sbuswell's Avatar
I need 2 more gears
so the purge control selonoid is connected to the intake manifold? what does it do?
Old Sep 1, 2005 | 10:54 PM
muffaburn's Avatar
Show me da MONEY
I am having this same issue (I think). The temp here in Atlanta has been ranging from mid/up 80's to mid/up 90's so I don't know why mine has gotten louder if that is indeed the problem. As I step on the gas the ticking gets louder and increases with speed, I only here it under a load, in other words if I put it in Neutral or park and step on the gas I won't here it. I tried fuel injector cleaner and also a additive that suppose to quiet valve tapping, it got quieter(sp?) for a couple of days than came back. I thought it could have been a low oil issue at first, oil level was fine(using Mobil1 5W30, maybe it's to thin for the summer temps ). If this is indeed due to the purge solenoid is it something I can replace myself since I am out of warrenty? Part#??? Another possibilty could be an exhaust leak, I have had my OBX headers on for almost two years with no problems so i don't think it's them
Help, the ticking is annoying me even my wife noticed
Sorry for getting longwinded, just wanted to be detailed so folks could have a clear understanding of the issue.
Old Sep 15, 2005 | 05:57 PM
zeek0666's Avatar
4th Gear
pcs
purge control selonoid part # MX136200-2110
Old Sep 20, 2005 | 12:05 PM
fog80's Avatar
I am getting a ticking as well, but it starts as soon as I start my car. Even when its in park, I hear this ticking.
Is this the same as your problem?
Old Sep 20, 2005 | 01:20 PM
fsttyms1's Avatar
where is it coming from? the engine compartment or around the rear wheel on the drivers side
Old Sep 24, 2005 | 08:09 PM
muffaburn's Avatar
Show me da MONEY
Well, I replaced the pressure control solenoid and I am still getting the damn ticking noise when I step on the gas when in drive. As stated before it does not tick when in park or neutral. Any other ideas?
Old Sep 24, 2005 | 09:17 PM
NSXNEXT's Avatar
Valve tap?
Old Dec 17, 2010 | 11:41 AM
tomf's Avatar
03 Type S - 153,000 miles
Valve Tap ?? I need to replace my purge solenoid valve as well. Where do i find the DIY threads ?
I am also noticing a ticking noise near my front passenger side area - after a cold start, then it goes away. Is this related ??
knight rider
Mar 4, 2016 08:59 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
adreano17
Sep 29, 2015 08:48 AM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
Brandle34
Sep 23, 2015 07:20 PM
