Problem when starting car
Old Apr 7, 2009 | 04:29 PM
2000_acuratl's Avatar
Exclamation Problem when starting car
Hello acurazine i am new here.
anyways i have a problem, sometimes when i try to start my car it try's to start but it starts dying. and somewhere around my exhaust pipes it starts knocking, so i have to sorta rev it up for it not to die. what can be the problem. Sometimes it does on warm starts and sometimes cold. it just does it random. No check engine lights coming up either.
Old Apr 7, 2009 | 06:37 PM
Rajca's Avatar
wham bam thank you ma'am
hows the air filter, clogged?. try seafoaming the car, gas tank, intake, and oil to clean the injectors and cat. manually clean the egr port which gets clogged of over time. their is a diy for all of the things i mentioned.
Old Apr 7, 2009 | 07:49 PM
Originally Posted by Rajca
. try seafoaming the car, .
i dont wanna seafoam the car because i read the diy for it and if you dont do it right it will mess up your engine badly. but to pay someone its real spendy, i did pour in some fuel injector cleaner and it helped a little.
Old Apr 7, 2009 | 08:44 PM
Rajca's Avatar
theirs a spray and a dip method. spray is so much quicker and easier. dipping isnt hard at all. try to pm a couple ppl that are on the board and see if they can help u
Old Apr 9, 2009 | 06:56 PM
Ric99tl's Avatar
I had same problem on my 99TL, it happened intermittently and only after warm up. Car would start, but as soon as I released key, car would die. Sometimes all lights on dash would turn off as well. After several attempts, car would finally start. Problem was the ignition switch was intermittent. Replaced switch ($70) and no more problems.
Old Apr 9, 2009 | 11:45 PM
juanclopez2786's Avatar
sounds like its bad/clogged injectors.. where are you from?
Old Apr 13, 2009 | 06:01 PM
spoka's Avatar
From the sounds of it you're probably looking at a fuel issue. How many miles do you have on your 2000 and have you ever replaced the fuel filter/pump??
Old Apr 13, 2009 | 06:44 PM
I live in the state of washington, but i dont know if the fuel pump/filter has ever been changed. I am the second owner
Old Apr 13, 2009 | 08:28 PM
3.2TLc's Avatar
As previously mentioned.....clean the "egr" ports ! If they are restricted, the engine can't breath and causes runability issues. Another thing to check would be the fuel pump relay.
Old Apr 13, 2009 | 10:25 PM
where is the egr located in the engine and what is it?
Old Apr 13, 2009 | 10:37 PM
Rajca's Avatar
search the diy for egr cleaning, u have to take off the intake manifold to get to it, its inside the intake manifold.
Old Apr 14, 2009 | 12:25 AM
spoka's Avatar
breathe?
The Exhaust Gas Recirculation valve is used to recirculate exhaust gas back into the combustion chamber to help burn atomized fuel and keep the combustion temperature down, therefore preventing NOX which is caused by heat and pressure.
The "EGR" is an emissions device, if restricted or stuck closed your engine would operate under normal conditions with a loss in fuel economy. If it were to fail in the open position you would definitely have a rough idle and lack of power.
Old Apr 14, 2009 | 12:37 AM
spoka's Avatar
That "knocking" noise you're hearing is probably the fuel pump located under the driver side rear of the vehicle. If you have a significant amount of mileage and have yet to replace the fuel filter I highly recommend replacing the filter and pump.
Old Apr 14, 2009 | 04:45 AM
Rajca's Avatar
fuel pump is in the trunk along with the filter.
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
