Oxygen Sensor?
Old Mar 19, 2008 | 01:07 PM
JeniferluvsAcuras's Avatar
Lightbulb Oxygen Sensor?
What brand I should
choose for my oxygen sensor?
I believe I need the ONE IN BACK OF
THE CAT UMMM I GUESS THAT'S IT I DUNO?
Old Mar 19, 2008 | 02:28 PM
fsttyms1's Avatar
OEM. and there isnt one in back of the cat. There is one at the cat and one in front of the cat
Under exhaust.
http://www.acuraautomotiveparts.org/...catdisplay.jsp
Old Mar 19, 2008 | 02:31 PM
LIPPSTUH's Avatar
Unregistered user
lots of people say do not get those universal ones where u have to use your old connector. the connection will not be as strong....
denso and bosche are good
Old Mar 19, 2008 | 02:57 PM
TLer trash's Avatar
What is your symptom? Has your check engine light been on? I'd hold off on buying a rear O2 sensor without some assurance that it's bad. I can't think of any running problems it would cause.
Old Mar 19, 2008 | 03:01 PM
My Check Engine Light Has Been On For Like 7 Months Now. A Diagnostic Test Showed Egr Valve Then Catalyst Problem....i Changed The Valve Cleaned The Throtle Body And Now I Am Going To Change The Sensors. I Dont Think It Is My Cat Cuz My Car Doesnt Have Any Smell Coming From It. I Beleive Its Jus An Emissions Problem. ??
Old Mar 19, 2008 | 03:41 PM
fsttyms1's Avatar
Have you reset the ECU after doing such things to see if the problem was solved?
What was the exact code. We can better help knowing that
Old Mar 19, 2008 | 03:47 PM
01tl4tl's Avatar
You need to remove the intake manifold and clean the EGR passages- changing the valve itself will not clear the crud-exhaust residue buildup in the very small passage the air moves thru.
see this DIY https://acurazine.com/forums/showthread.php?t=156252
Then run Seafoam thru the intake manifold and the gas to get it really clean again.
Disconnect the battery to reset the CEL by resetting the ECU Engine Control Unit- so it starts new... learning how the engine is running and testing systems function
If that doesnt clear the CEL- have the O2 sensor electrical resistance checked.
If it fails the test parameters- replace
Emission problems are serious on the TL- its Ultra Low Emission status means near zero stuff out the tailpipe. The CEL is on for a reason!!!
Got new spark plugs yet?
Old Mar 19, 2008 | 03:48 PM
TLer trash's Avatar
The egr code would point to plugged egr passages. I believe there's a d.i.y. on the procedure. Unfortunately, if you had a catalyst efficiency code it's probably the catalytic convertor. A lazy rear O2 sensor would be less likely to set that code than a new one. If the catalyst isn't plugged, you can pick up a "dummy" sensor, or a spacer to go between your sensor and the cat. I think one or more of the vendors on this site can help you.
Old Mar 28, 2008 | 04:05 PM
yes
Old Mar 28, 2008 | 04:26 PM
fsttyms1's Avatar
Originally Posted by JeniferluvsAcuras
yes
And?? what was the codes?
Old Mar 29, 2008 | 06:09 PM
I know that would help.....but I don't remember!
Old Mar 29, 2008 | 07:36 PM
FirePR2002's Avatar
bringin lead
Speaking of codes. Get and write down your radio code before disconnecting the battery for ECU reset.
RobbDizzle
Oct 15, 2015 11:16 AM
samson_420
Oct 8, 2015 01:47 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
prbori
Sep 27, 2015 01:37 AM
