Overheating!!
Old Nov 8, 2007 | 09:25 PM
Bambo2888's Avatar
they go wooooot wooooot
Overheating!!
Ah guys, got an overheating problem. At idle with no movement, the temp shoots up to just under red.
When I put the heater on high or start driving, the temps immediately return to normal. There is a full reservoir of coolant, which is not normal (usually half full).
Any ideas??
Old Nov 8, 2007 | 09:42 PM
fsttyms1's Avatar
Are your fans turning on?
Old Nov 8, 2007 | 09:50 PM
sbuswell's Avatar
I need 2 more gears
any coolant leaking? the overflow in your coolant reservior sounds like a bad thermostat. the fact that the temp drops while you drive is strange though. could be a leak causing a loss in pressure in your cooling system. Is your CEL on?
Old Nov 8, 2007 | 11:08 PM
Bambo2888's Avatar
both fans work, no CEL, and yea, the coolant level in the overflow tank is rather high, about a 1/2 inch from the top.
Old Nov 9, 2007 | 08:54 AM
fsttyms1's Avatar
whats the level like in the radiator?
Old Nov 9, 2007 | 09:01 AM
Bambo2888's Avatar
How can I check that? Just by taking the cap off?
Old Nov 9, 2007 | 09:23 AM
Bob_F's Avatar
Yes, remove the cap. If you haven't done that before, you'll want to do that with the engine cool. People get burned all the time...
Old Nov 9, 2007 | 09:30 AM
Bambo2888's Avatar
When i took the cap off, I can see coolant about a cm or so down, so i guess that;s filled also.
Old Nov 9, 2007 | 10:58 AM
fsttyms1's Avatar
I would start out by replacing the thermostat
Old Nov 9, 2007 | 11:06 AM
Bambo2888's Avatar
you dont think a flush would do anything?
Old Nov 9, 2007 | 11:18 PM
sbuswell's Avatar
I need 2 more gears
your thermostat is gone, probably stuck shut. Either that or someone poured extra collant into your overflow.
Old Nov 10, 2007 | 06:56 AM
Bambo2888's Avatar
alright, i guess ill do the thermostat today and check back with yall. any links to info on the thermo?
Old Nov 10, 2007 | 07:58 AM
fsttyms1's Avatar
Part#4
Easy to get to.
Old Nov 10, 2007 | 09:52 AM
JetBlackAC's Avatar
how much does a new thermostat run
Old Nov 10, 2007 | 10:34 AM
Bambo2888's Avatar
from what i have been told $10-20, i dont know for sure though.
Old Nov 12, 2007 | 08:58 AM
fsttyms1's Avatar
26 bucks OEM
http://www.acuraautomotiveparts.org/...catdisplay.jsp
Old Nov 14, 2007 | 06:36 PM
NighthawkBlack's Avatar
I have the same problem. Sitting at idle for more than 10 min causes temp to rise and I start to get detonation until I drive a little and temp cools down. Is that the thermostat or water pump?
Old Nov 14, 2007 | 10:28 PM
runyun's Avatar
Did you have work done previously? Could be an air pocket.
Hopefully you didn't drive the car overheated for a prolonged time. Then, you could possibly have a leaky headgasket. Does your coolant boil inside your resevoir during or when you turn off your car?
Old Nov 14, 2007 | 10:29 PM
runyun's Avatar
denonation? not sure
check your efans.. see if they come on at all
Old Nov 17, 2007 | 01:13 PM
Bambo2888's Avatar
for the record, the problem is solved
I disconnected all of the coolant hoses. I flushed everything out (hoses, radiator, coolant inlet and outlet, and resevoir). I alos replaced the themorstat, which was nice and easy (two bolts right under the throttle body).
everything now works perfectly. also, for all those having over heating issues, MAKE SURE that there is a hose connected to the inside cap of the overflow resevoir.
Old Nov 17, 2007 | 10:54 PM
Bob_F's Avatar
Thanks for the update. Do you suspect any particular thing as the cause?
Old Nov 18, 2007 | 08:36 AM
fsttyms1's Avatar
The thermostat
Old Nov 18, 2007 | 03:14 PM
Bob_F's Avatar
Originally Posted by fsttyms1
The thermostat
Yes, that's what I would suspect.
Old Jul 10, 2008 | 09:25 PM
DC3328's Avatar
Your Garage
so the car really wasn't overheating? it was just the thermostat?
im having the same problem
Old Jul 10, 2008 | 10:59 PM
sbuswell's Avatar
I need 2 more gears
if your thermostat is closed shut your car will overheat quickly. Get it replaced.
Old Jul 11, 2008 | 01:03 AM
doughboi33's Avatar
The thermostat has a pellet inside of it which melts at certain temp to let u know that the temp is rising. With the age of the car usually theses pellets get stuck and causes you too FREAK OUT because you think you car is about to blow up!!! i had the exact same problem and fix it by replacing my coolant system rad, upper/lower hoses, and thermo. Problem has yet to occur again for about 2 weeks everything was done almost a month ago.
Old Jul 11, 2008 | 08:34 AM
hendricknick's Avatar
9th Gear
This may sound stupid, but i had the same problem and thought it could be a number of things. I had the system pressure tested and everything was ok...no leaks. But I replaced the radiator cap which looked like it was leaking and topped the coolant off and I haven't had a problem since. I bought a NAPA cap for something like $5 and everythings great.
Old Jul 11, 2008 | 09:24 AM
fsttyms1's Avatar
Yea the car really WAS overheating. If the thermostat isnt opening the car over heats.
Old Jul 11, 2008 | 12:48 PM
DC3328's Avatar
Your Garage
oh ok just making sure cuz i had to air mine out before i could turn it on again, :ordersthermostat:
thx for the help guys
Frathora
Sep 28, 2015 11:29 PM
NSolace
Sep 3, 2015 08:14 PM
NSolace
Sep 3, 2015 08:02 PM
Jezek
Jun 20, 2006 11:30 PM
gincali
May 17, 2006 09:01 PM
