oil pressure
Old Feb 10, 2008 | 03:35 PM
cominfromafar's Avatar
Casper
oil pressure
What should the oil pressure be for a '99 acura tl?
The repair manual says 71psi @ 3000rpm for the 1999 J32A1/UA5 engine.
I have two gauges.
*****Gauge 1 --- 0-100psi scale (in 2psi steps), xxx manufacturer guage*****
At idle (750rpm) and warm engine, i get 28psi.
At 3000rpm, i get 84psi.
*****Gauge 2, 0-300psi scale (in 5psi steps), KD Tools gauge*****
At idle (750rpm) and warm engine, i get 30psi.
At 3000rpm i get 90psi.
First off, it's odd that when at 3000rpm, the KD tools gives me 90psi instead of the expected 85psi. Could be some calibration issues even though i just purchased both of them and expected them to be ready to go.
More importantly, am i in danger since my oil pressure is 84psi @ 3000rpm when the manual states it should be around 71psi @ 3000rpm?
If it is bad that the pressure is this high, what could be causing it?
Old Feb 11, 2008 | 07:36 AM
fsttyms1's Avatar
I dont think its that bad. Does it get higher as the RPMS build?
And why are you testing it anyway? do you suspect something is wrong?
Old Feb 11, 2008 | 08:52 AM
mtsesrs1's Avatar
03 TL-S
Other questions to be asked?
New Motor, Old Motor, How many miles, Type and weight of oil, Stock oil pump, (High Volume pump (Doubt it) . A number of variables you have left out we do not know. As a gereral rule 10psi per 1000 rpm keeps a stocker together. Heavier oil produces more psi. Oil cold produces more. Too much pressure 100psi + can be bad as well as too little psi less than 10 @ idle. A little more info can help.
Old Feb 12, 2008 | 03:36 PM
Casper
Sorry about the lacking info, here it is:
Fully original stock motor (w/ stock oil pump) and tranny with 106,700 miles.
Oil grade/weight is currently [Castrol Syntec] 5w-30, and it's been about 1,500 miles since i last changed it. I change it every 3,000 miles.
I can't say if the oil pressure goes higher than 84/90psi (w/ the two corresponding gauges) if i rev it past 3,000rpm because i didn't go much past that. I revved to 3,250rpm at most, and noticed that the needle (on the 100psi scale gauge) was just teetering at 84/85psi. I'll try revving it higher and post the results.
I did also observe what you said about cold oil producing more pressure, and so i did let it warm up for at least 1 radiator fan cycle, or for more than 7 minutes. The readings which i posted above were well into the warming period (radiator fan cycle, upper radiator hose very warm, and more than 7 minutes had passed), and after i saw the fluctuations due to cold oil.
The reason i am doing this is because my oil pressure light was coming on, blinking slowly and fast sometimes. I suspected that it was a sensor, but being paranoid and careful, i decided to check to see if the pump was operating correctly.
I hope i haven't left anything out this time...
Old Feb 12, 2008 | 03:44 PM
Casper
I forgot to note that i will be seafoaming the engine/fuel system and then putting on the new oil pressure sender.
Old Feb 12, 2008 | 04:15 PM
fsttyms1's Avatar
I would say possibly a faulty sending unit ? (also check the alternator output) Does your VTEC work properly?
Old Feb 12, 2008 | 10:08 PM
Rajca's Avatar
wham bam thank you ma'am
did u put an after market oil pres. gauge in? bc if u did i need some help with mine.
Old Feb 16, 2008 | 12:54 AM
Casper
Well i tested it again, and (w/ a warm enginge) the oil pressure was 96psi @ 4000rpm. I didn't want to take it above 4,000rpm. I really suspect that there is a blockage somewhere. But being that i need the car up and running to get work done immediately, i connected the new pressure sender unit, and will seafoam the crankcase while keeping an eye on things since there seems to be no low pressure/pressure loss. I know, i'll probably have to change the sender unit again due to the seafoam procedure.
Raj, i did not connect an aftermarket oil pressure gauge, so i don't think i can help. But you can still ask and someone will have an answer..
fst, how do i check if the VTEC system is operating properly? I hear no engine knock or anything. The alternater/ground wires look fine.
Old Feb 16, 2008 | 01:08 AM
2K3_TLs's Avatar
OMGWTFVTEC
Take your car out for a drive, past approx 3800 RPMs, thats when VTEC engages for your TL. You should note a change in sound when VTEC kicks in, however slight it may be.
Old Feb 16, 2008 | 01:34 AM
Casper
If i hear the sound difference, does this indicate that it's working properly (without any problems) or just that it's working (with glitches, however minor it/they may be)? The car is still on jack stands (i'll finish up bolting everything when i get up later before i head to work), so i should be able to hear the sound if i rev it now right (i assume the transmission doesn't have to be engaged)?
Old Feb 16, 2008 | 01:56 AM
2K3_TLs's Avatar
OMGWTFVTEC
If you can hear it, it should be working properly... if it wasnt, I'm more than positive it would throw a CEL or something. I dont know how the 99's are when you rev it in park/neutral, but when I rev it up then, it bounces off at approx 5-5.2k RPM as if it were hitting the limiter, then again my VTEC engages at 5k.
Old Feb 16, 2008 | 01:58 AM
Casper
ummm, just to verify that i didn't do all of this for nothing and so i don't feel like an idiot, there is no reset procedure after an oil change on '99 TL's right? The reset procedure is for gen 3 and onwards only?
The manual says to change the oil, turn the engine on, and the oil light should go off in 5 seconds. I didn't read anything about a reset procedure.
Old Feb 16, 2008 | 02:00 AM
Casper
Ok, i'll test the vtec on an open road then.
Old Feb 16, 2008 | 02:18 AM
2K3_TLs's Avatar
OMGWTFVTEC
there is a reset procedure for the "Maint Req'd" light. It explains how to reset it in your user manual. I dont know it off hand though. All it is, is a reminder... it comes on and flashes after 5k mi, I believe... and then comes on and stays on after 7500... its just a reminder to change your oil and other maintenance items...
IBankMouse
Jun 13, 2020 12:53 PM
SidhuSaaB
May 30, 2020 12:40 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Thuneau
Oct 3, 2015 04:19 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
