Not Cranking
Old Sep 6, 2007 | 04:44 PM
Timslunch2's Avatar
Not Cranking
My 99 TL will not crank. I checked the stater fuse and wires going to the starter and still nothing. All the lights light up and dim alittle when I move the key to start position and I could hear a relay or something click oin the fuse box in the engine bay. Any other things I could check before I have this heep towed?
Old Sep 6, 2007 | 04:46 PM
Bob_F's Avatar
How bright are the headlights?
It could be something as simple as a dead battery.
Do you have a charger?
Have you tried a jump from another car?
I'd check the battery or try a jump before having it towed.
Old Sep 6, 2007 | 05:24 PM
Timslunch2's Avatar
Thanks Bob but its not the battery all lights come on strong. This what I did with the car in park i turn the key and get a little click from the fuse box- If I put the car in gear I DO NOT get a click. my green key light is turning on and blinks 4 or 5 times when the key is taken out of the ignition as of now I would say its the starter but never got a warning sign or anything that indacated it was bad. It just worked fine and then nothing. I have beaten the sh!t out of the starter and it will not crank at all. Is there anything else I could check before I go down this road?
Old Sep 6, 2007 | 07:19 PM
01tl4tl's Avatar
99s had an ignition switch recall- call acura 1-800-382-2238 x5 6am to 5pm pacific time have your VIN number handy, and even the replacements fail too!
Old Sep 6, 2007 | 07:37 PM
Bob_F's Avatar
That's a great idea. I should have thought of that as my 1999 TL is on its third ignition switch.
acuratl26
Apr 23, 2020 07:30 PM
02tljj
May 2, 2019 08:56 AM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
