Noise problem?
Old May 29, 2012 | 10:40 AM
tman11's Avatar
Noise problem?
So after my car is in park for around ten minutes and then I put it in drive again it makes this noise only once or twice and then stops. Anyone else have the same problem or know what it is? Thanks
Old May 29, 2012 | 10:47 AM
fsttyms1's Avatar
once when you put it in gear, once after starting to drive? If so its just the ABS self check/test and is normal and supposed to do that.
Old May 29, 2012 | 10:59 AM
tman11's Avatar
It's once I start driving a little bit. It's not like a beeping tho
tman11's Avatar
Idk how to describe the sound but I hope it's not my trans
Old May 29, 2012 | 11:20 AM
marso's Avatar
Are you the same Tman that's on SQC?
Old May 29, 2012 | 11:41 AM
tman11's Avatar
Idk man lol
Old May 31, 2012 | 08:17 PM
HondaProtegeX2.3's Avatar
B A N N E D
sounds like the abs tester but that usually happens when you first start the car but maybe since the car has been parked for so long running it might run another cycle?
Old May 31, 2012 | 08:18 PM
B A N N E D
check your power steering fluid level see if its above the low level, if your power steering fluid is low it will make a weird humming and weird noise it might have a slight leak or something
snorf
Nov 4, 2019 06:44 AM
real_mckoy
4G TL Problems & Fixes
Sep 25, 2015 10:49 PM
njresendez
Sep 21, 2015 11:23 AM
iCrap
Sep 11, 2015 06:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
