2002 3.2 TL - rough idle on start up
Old Jun 1, 2012 | 10:25 AM
AofD4me's Avatar
Lately when I crank it in the morning after it's sat overnight the car idles roughly...not violently, but noticeably.
Clogged injectors? Dirty air filter?
Old Jun 1, 2012 | 11:14 AM
dreem1er's Avatar
deal with it
seafoam it, and maybe you need new plugs, you buy the spray seafoam and spray straight into the throttle body, and the liquid can and have the engine suck it up, pour into the gas tank, combo of both
Old Jun 1, 2012 | 02:19 PM
Skirmich's Avatar
IACV: if the RPM is jumping....
PCV: if Rough Starts but can also lead to IACV.
Old Jun 1, 2012 | 05:28 PM
zmwang's Avatar
on startup, rough is a designed feature. Nothing wrong.
It needs misfire to heat up the CAT.
Old Jun 1, 2012 | 06:10 PM
Skirmich's Avatar
Where did you Hear that?
Missfire is a very bad Thing it cannot be by default....
Our car Heats up the CAT by Closing the Loop A/F Ratio.
Old Jun 1, 2012 | 09:33 PM
Type-ES's Avatar
Yes they can, our cars miss (no spark is sent so fuel goes into cat warming it quickly)
Also newer cars will "misfire" when the fuel level is too low to alert the driver. And some engines with CVTs will "misfire" to simulate gear change.
Old Jun 1, 2012 | 09:45 PM
zmwang's Avatar
google a bit and you know what I mean.
The misfire is less than 2% and won't trigger CEL.
Old Jun 1, 2012 | 10:07 PM
01tl4tl's Avatar
our rough idle is often the EGR system is clogging and ready for its diy cleaning of the intake manifold,,,every 75kmiles its due
CK PCV valve in rear valve cover for free movement of ball inside
do Seafoam thru gas tank to get the injectors and fuel system
1 16oz can to 8 gal fuel - just under half tank
do that twice and its better than manifold vac method (which is instant cleaner for many parts and worth doing) but you can do it all thru gas twice if nervous
Plus clean throttle body air plate
ck air filter
how are the plugs? age/miles?
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
Caddy
1G RDX (2007-2012)
Sep 18, 2015 12:44 PM
Mike Bertram
Sep 10, 2015 09:27 AM
NSolace
Sep 3, 2015 08:14 PM
