No Heat
Old Feb 20, 2006 | 11:09 PM
optomos's Avatar
I=X - optomos
No Heat
Its blowing cold/cool @ 90 degree setting. I havnt had time to diagnose yet, but wondered if anyone else had this problem before and knows what it is.
I hope its not the heater core
Old Feb 21, 2006 | 06:01 AM
honda_inspire99's Avatar
Skeet Skeet Skeet
mine blow hot even at 60 degrees now it doesn't it work at all
Old Feb 21, 2006 | 08:25 AM
optomos's Avatar
I=X - optomos
Hm, you might have a few problems. Have you tested anything yet? Is it blowing at least cold air?
I looked at the fuses on drivers side and under the hood. Now I need to test the heat blower relay under the hood and check if the heater core is not plugged. It sucks having a problem that not many people have run into.
Old Feb 21, 2006 | 10:02 AM
fsttyms1's Avatar
also may be the actual dash temp control.
Old Feb 21, 2006 | 12:21 PM
optomos's Avatar
I=X - optomos
I found out what my problem is. It is the "control valve" aka "heater valve".
You can see the picture of the part **HERE**
It's $50 at the dealer or you can get it for $29 **HERE**
So if you have no heat, it's still blowing air, you don't have water on the passenger side floor or condensation on your windshield, look at this first.
Fsttyms, I think you are right about the temp control being inspire99's problem.
Old Feb 21, 2006 | 12:38 PM
fsttyms1's Avatar
Cool that you found it.!
Old Feb 21, 2006 | 01:27 PM
satori's Avatar
I'm having the same problem. Where is this valve located and how hard is it to switch out?
The part listed is for 99-00, does this apply to an '01 as well?
Old Feb 21, 2006 | 01:54 PM
optomos's Avatar
I=X - optomos
Here's pictures of the part
It's almost in the center of the firewall.
Satori, call the 800 number on the second web site & ask them about that part for a 01. I did see that part available for that year on their site.
Old Feb 21, 2006 | 06:07 PM
Skeet Skeet Skeet
thats probly my problem too because i tried mving the little handle on the valve with my hand and it wouldn't move so i'm going to heck it out tomarow
Old Feb 22, 2006 | 08:52 AM
satori's Avatar
Thanks I'll take a look at it.
Have you switched yours out? Did it fix the problem?
Old Feb 22, 2006 | 10:07 AM
optomos's Avatar
I=X - optomos
Mine was stuck so I just played with it and got it to work. I ordered a new one yesterday because even though its working now it still needs to be replaced so I dont have to deal with it again. Not a big deal to replace; two clamps & hoses.
Post again if you guys get yours fixed.
Old Feb 24, 2006 | 11:22 AM
satori's Avatar
Well I haven't ordered a new one yet but I played with it and it loosened up...seems to be working fine but I know I'll have to replace it soon.
Thanks for the help
Old Feb 24, 2006 | 12:28 PM
fsttyms1's Avatar
well for grins last nite while i was in the process of getting my engine ready for removal i played with mine and mine was really hard to move (but i know mine works) so are you sure that thats the problem
Old Feb 24, 2006 | 12:47 PM
optomos's Avatar
I=X - optomos
Yes it is like that. The only way to tell is have someone inside the car after it has warmed up and set the dial to 60 then have someone watch the valve while the person inside the car turns on the heat and moves the dail towards 90. If it works, the valve should open/move towards the passenger side, if not then it won't move at all.
Old Apr 3, 2006 | 08:12 AM
payyourtoll's Avatar
just happened to me, got in this morning, drove an hour to work with no heat. blowing cold air, whether temp is at 60 or 90. I will post back what the fix is.
Old Apr 3, 2006 | 10:22 AM
optomos's Avatar
I=X - optomos
Its this part that is bad
I replaced it when I did my headers. I will tell right now that the bolt that holds the bracket to the firewall was a pain to remove and it would have been a nightmare if the downpipe was still there.
Old Apr 3, 2006 | 10:36 AM
greeeeaaaaat
Jul 16, 2017 07:33 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
TL14
Sep 24, 2015 04:37 PM
