need serious help wit wierd problem.
Old Apr 27, 2009 | 07:18 PM
rk5tar's Avatar
ok well yesterday night i was in the burger king drive-thru waiting my turn to get my order when all of a sudden the VSA and /!\ come on and wouldn't turn off so i freaked and turned my music down to think about was was going on. after i payed i went around and parked in the parking lot, turned the car off and let sit for 2 min then turned it back on, when i did the VSA and the /!\ went away. then today at work i was playing my music really loud with my subs turned up all the way while i was parked in the parking lot, i had my car on so it wouldn't drain the battery then all of a sudden the 2 lights pop back on again. so i was starting to figure maybe it was my subs causing the problem but didn't really think so because it had nothing to do with the VSA function, so i took it to autozone and they could'nt scan it so i tried to turn my music up again to see if it really was the problem, and after 10 secs they were back on, wierd part of it is that they never turn on when im not blasting my music, so then i figured i should take it to a shop they scaned for any codes but found none. im really confused right now and just want to know what the problem is and how too fix it so if anybody has a clue please help me out
Old Apr 27, 2009 | 08:32 PM
totaledTL's Avatar
Excessive current draw confusing the ECM, maybe-
Old Apr 27, 2009 | 08:59 PM
spoka's Avatar
check the pressure in your tires
Old Apr 27, 2009 | 09:19 PM
rk5tar's Avatar
i was kinda thinking that since its only when the music was on full blast that maybe the heavy vibrations are messing with the sensors from the VSA but since i don't really know anything about this im not sure whats going on. Hopefully i can get a solid answer from someone because this is driving me crazy
Old Apr 28, 2009 | 12:30 AM
rk5tar's Avatar
bumped the thread because i really need to know what the problem is
Old Apr 28, 2009 | 06:30 AM
totaledTL's Avatar
How old is the battery? What's the voltage across it when you must have that blaring?
Old Apr 28, 2009 | 07:25 AM
fsttyms1's Avatar
That light often comes on with the CEL light and usually has nothing to do with the VSA. Odds are your current draw is more than your battery/alt can put out causing the light to come on temporarily. How old is your battery?
Old Apr 28, 2009 | 08:09 PM
rk5tar's Avatar
im not sure but i bought my car used 3 months ago so im not sure how old the battery is
Old Apr 28, 2009 | 08:41 PM
MurdaZ's Avatar
can u turn off the vsa when the car is still running and not having to shut the car off?
Old Apr 29, 2009 | 12:59 AM
rk5tar's Avatar
nope only when i turn the car off.
MilanoRedDashR
Oct 8, 2015 10:30 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
ceb
ILX
Sep 27, 2015 10:56 AM
prbori
Sep 27, 2015 01:37 AM
