need answer asap- alternator compatible?
Old Feb 21, 2014 | 10:24 PM
Chevelle66's Avatar
My alt just died tonight, need to replace asap. Is it accurate that a 2003 honda pilot alt will fit a 2000 TL? I want to get it cause it's is not only more output but I can get it cheaper.
What others will be a direct replacement?
Also, has anybody used a brand called "quality-built"? It lookes decent and is even cheaper with a good warranty
Old Feb 21, 2014 | 10:28 PM
just wondering how you came to the conclusion of it being the same part?
I did not research anything and do not know the answer, was just curious why you think the honda pilot would fit.
side note; if it has the same mounting points and not much larger than the TL's, yes it will work.
Old Feb 21, 2014 | 10:41 PM
Chevelle66's Avatar
Was looking at various alts, looked at ebay and the alt I know fits the TL was also listed at fitting 03/04 j35 Pilots and odyssey. Just wanted to confirm.
Old Feb 21, 2014 | 10:44 PM
if its not much bigger and has same mounting points, it will fit.
i dont know for sure, just going off of shape and mounting points
Old Feb 21, 2014 | 11:09 PM
ErickUa5's Avatar
Mr.Helpful Diagram
From what it looks it might fit but the connectors don't look the same for the voltage regulator. Compare before buying!
Old Feb 21, 2014 | 11:17 PM
Fuck it, BIGGER is always better right?
*Cue Tim the TOOL man Taylor's Manly Grunt*
Old Feb 21, 2014 | 11:21 PM
I live in Texas.
and Every thing is bigger!
I have a 3G, and I feel the stock alternator is adequate enough for everything that I can throw at it.
if the part listing is correct, it says it fits my car as well.
That would lead me to believe that it will fit and be enough to recharge the battery.
Last edited by justnspace; Feb 21, 2014 at 11:24 PM. Reason: found a mistake because I'm getting D-R-U-N-K.
Old Feb 21, 2014 | 11:31 PM
cincinattlguy19's Avatar
06 NBP 6MT TL
TL-P is 105 amps
TL-S is 120 amps
Pilot/Odyssey/MDX is 130 amps
All will fit and be direct bolt ons. I know some of the guys running huge audio systems upgrade to the Odyssey alternator.
Old Feb 21, 2014 | 11:37 PM
Chevelle66's Avatar
Originally Posted by cincinattlguy19
TL-P is 105 amps
TL-S is 120 amps
Thanks!
Ya I want the 130a cause I'm going to be running about 1060w to 1260w rms.
Any suggestions on a brand? Denso is damn expensive.
Old Feb 21, 2014 | 11:42 PM
GO oem fool!
how are you gonna decide on the alternator with the highest amperage, but then cheap out on the brand.
a cheapy brand will most likely not output the claimed amps!
Denso.
Old Feb 22, 2014 | 12:34 AM
ErickUa5's Avatar
Mr.Helpful Diagram
Lol yea justnspace thats what they say.
Good to know that information thanks cincinattlguy19.
Old Feb 22, 2014 | 02:16 AM
Chevelle66's Avatar
Thanks guys. Getting a reman 130a pilot alt from pep boys, having their anniversary sale so it's the cheapest anywhere with 21% off when ordered online and store pick-up. Just grabbing it to get it driveable til I can get a true high output alt.
One more question though, why the heck are the TL alts more expensive than the pilot/oddy ones everywhere? Makes no sense if they're basically the same.
Old Feb 22, 2014 | 02:30 AM
Chevelle66's Avatar
Oh and just to verify, it is a 2003/4 Pilot/Oddy, not 2000 etc right?
Old Feb 22, 2014 | 03:04 AM
Chevelle66's Avatar
Hmm, after some reading, I think I may have a bad ac tensioner, I have a new squeak that started same time as my alt output stopped. But when I raise the rpms, output increases. Would a bad tensioner cause the alt not to spin? Or is could it just be the alt bearing? I does sound like it's coming higher up than the alt.
Old Feb 22, 2014 | 06:56 AM
3.2TLc's Avatar
Have ya tried spraying some WD40 on the tensioner to see if the "squeak" goes away ?
Take the belt off and check if the bearing spins freely by hand.
If the belt tension is good, have the charging system load tested.
By the way, the "OEM" original alternator can be rebuilt and upgraded by an electrical specialty shop.
Old Feb 24, 2014 | 09:11 PM
Chevelle66's Avatar
Got a new tensioner and 130a alt on, seems to be working great overall. Idle output seems a little weak, but the slightest above idle is great. Some reason my idle seems just a tiny bit lower sometimes then before the alt change according to dash, haven't checked with scanner yet, but I'm 99% sure it is lower.
Only the 03+ needs the idle relearn right?
Jul 16, 2017 07:33 AM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
adreano17
Sep 29, 2015 08:48 AM
mars
Sep 28, 2015 11:03 AM
