My HEAT DOESN'T WORK!
Old Sep 5, 2006 | 10:58 PM
-Vip3r-'s Avatar
ABPUA5
lemme start by saying this is my first post on this forum i browsed around for a month or so and finally decided to join. i have a 02 tl-s with navi that i got around july 20th or so that i bought used with 49500miles on it.
well..it was a little cold here in nj the other day and i decided to turn my heater on, so i put the climate control to 90 and turn the fan onto like 3 and the A/C off.. about 5 minutes later..no heat. i was like wtf? so then i waited maybe i was like the heater hasn't been turned on forever maybe something is up with it lemme just let it run, well..turns out..still doesn't work! i made sure the A/C button wasn't on or anything..heat just does not want to work. so i tried messing with the temperature on the climate control..it doesn't do a god damn thing.. so basically my temperature is set to some constant temperature which i don't know what it is. if it's 60 or 90 it still blows a constant temperature out. i was wondering why during the summer my A/C felt like it wasn't that cold even with it blasted in hot 90degree weather.. i have no clue on what to do..the previous owner had gotten the whole A/C system redone because it wasn't working at all i can't exactly remember what he got done but i remember when i went to test drive it the A/C system didn't work at all.. not even the fan, he was in the process of redoing the whole thing. he took it to the dealer, and when i went for the second test drive after he said he was getting the car serviced everything seemed fine such as the a/c and all..
one more problem is that my power steering fluid seems the need to be refilled from the min line to max every 3weeks to a month or so because it starts making this nasty groaning sound..once i refill it the noise tends to go away.. it's weird, like theres a leak or something.
Old Sep 6, 2006 | 09:07 AM
2ndgentl's Avatar
Heater problem
I had the same freakin problem and spent hours trying to figure it out myself. Here's what the problem was on my car. Right behind the engine, up against the firewall, I would say just about in the center of the firewall, you'll see a small pully lookin thing with cables on it. Well, it gets stuck sometimes and all it needs is a little lubrication on it. I guess its a pully system to engage your heater on, and when you turn your heater on it gets stuck sometimes. I put lubrication on it a year ago and its been working fine. Sometimes the biggest problem is always the littlest fix.
Old Sep 6, 2006 | 04:12 PM
bkzjimmy's Avatar
NiGhT rIdEr
i was gunna say thermostat.
about the stearing fluid...did u even check for leaks?
Old Sep 12, 2006 | 06:01 PM
-Vip3r-'s Avatar
ABPUA5
yeah i found the valve but..i put lubrication on it and still nothing.. how is it supposed to work, like what exactly is supposed to move or pull. it has a green cap on it too..i need explanation lol..thanks
Old Sep 13, 2006 | 07:09 PM
-Vip3r-'s Avatar
ABPUA5
bump i need help
Old Sep 13, 2006 | 08:48 PM
-Vip3r-'s Avatar
ABPUA5
actually..there is no pulley or anything you can pull..it's just a green cap that you can unscrew.. its weird. i'll try to get a shot of it later, butany other suggestions would really help
Old Sep 17, 2006 | 12:30 PM
2ndgentl's Avatar
2ndgentl
Sorry man its been a while since i've been on this site, but I just visually looked at it and its almost in the middle of the firewall, there are two big hoses going to them and theres only one cable wire on it that moves back and forth........lube it and have someone keep turning your heater on and off so it can break loose again, or just do it with your hand, you'll see the cable.
Old Sep 17, 2006 | 05:06 PM
-Vip3r-'s Avatar
ABPUA5
i found the valve..i put lubrication on it and it was hard as hell to even move.. after pulling on it really hard it got loose and i moved it to the middle where the heater is supposed to activate. but evenwith the valve in the middle still no heat comes on and it also doesn't moveby itself even though the valve is now loose.. any other suggestions? thanks
Old Sep 18, 2006 | 07:27 AM
2ndgentl's Avatar
2ndgentl
If it doesnt move back and forth by turning it on in your car then that should be the problem. Try moving it manually and have someone sit in the car to see if it works. But if its not that it could be your thermostat. But you said that you can manually move it back and forth but not electronically, so I would have someone sit inside and see if the heat does come on by manually moving it from the outside.
Old Sep 18, 2007 | 01:21 PM
JnC's Avatar
JnC
Former Sponsor
This should be made a sticky . Worked like a charm for me. The heater hadnt been working since i tried using it the past few days, I was contemplating taking it to the dealer but thought i should do a quick search here on the forum and whatdya know someone else ran into this issue as well and there was an easy fix . I guess with all the salt that our cars go through in the winter its not hard for that wire to get clogged with salt. I sprayed it with WD40 and let it rest for a few hours and after that manually loosened the valve and then checked the heater, upon turning it on and off it worked perfect. By the way when the heat is turned on the wire is extended to the fullest and when its off its retracted.
Old Sep 18, 2007 | 06:11 PM
fsttyms1's Avatar
if it doesnt move after that then the motor that powers it may be bad.
Old Sep 18, 2007 | 06:51 PM
acuratech25's Avatar
check your air mix motor
Old Sep 19, 2007 | 06:24 AM
JnC's Avatar
JnC
Former Sponsor
^^ I guess both of you, kris and acuratech didnt look at the thread start date lol. I bumped it cause the solution by 2ndgentl helped me so i thought bumping it might help others as well .
Old Oct 18, 2009 | 08:44 PM
thugindwnlow1's Avatar
May be i am just not too familiar with the Firewall and this green wire....but a PICTURE would be very helpful indeed!!..........cuz i can't seem to find it on my 99 TL. My engine is indeed very dirty cuz i've driven this car all over the country on the highways and all and i bet my car has the same isssue. Its starting to get cold and I can use any help. Similar problems as the guy above but CAN"t locate the wire????
Old Oct 19, 2009 | 08:06 AM
Luke7's Avatar
WNC Real Estate Sales99TL
Had the same problem as you a couple weeks ago. It was the Air Mix controller/servo motor. It had been clicking for 3 years and finally failed. Thus=no heat and only full air conditioning. It's located on the passenger's side of the heater assemble. Look up at the bottom of the heater assembly from the left side of the passengers side foot well. you will see a little control box that should move the Air Mix door when you raise and lower the Temp. on your heater. If it doesn't move and open the door that's the problem. $113.00 shipped for a new one. There are 3 screws (on the silver plate) that hold it up there and one wire assembly to remove. Very easy to replace if that's your problem. You can pull the carpet back for easier access. As Acuratech25 said/check this.
Old Oct 19, 2009 | 10:26 AM
smartypants's Avatar
Hi All :
I've had a similar issue for year, no heat and will only blow cold air. I have been able to correct it buy turning the heat all the way up and then back to the desired temp. Could this be this seized wire/pulley thingy on the fire wall ?
Also, as others have said....a pic is worth a thousand words......
smartypants.
Old Oct 20, 2009 | 12:47 PM
Oiling up the cable going into the firewall worked like a charm; took some pictures and will post them today "smarty pants"
Old Oct 23, 2009 | 06:15 AM
Luke7's Avatar
Well Vip3r did you find the problem?
Old Oct 23, 2009 | 09:21 AM
Rockstar21's Avatar
The Dumb One
thread is over 3 years old..
Old Oct 24, 2009 | 05:41 PM
Luke7's Avatar
Woops
AndrewS
19
Mar 14, 2024 06:59 PM
cycdaniel
Dec 17, 2019 10:58 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
acurajj
Sep 19, 2015 03:47 PM
dlknight
Sep 3, 2015 07:54 PM
