Motor Mount Vacuum
Old Apr 5, 2011 | 08:35 PM
grdprx's Avatar
Motor Mount Vacuum
Got a question regarding the vacuum. I'm looking at aftermarket mounts, and they say for the Front, "Does Not Include Vacuum Line Fitting" and on the rear, "Without Vacuum hose."
Is that going to be a problem? I don't quite understand. I think this means the front isn't vacuum assisted and that I'd have to reuse the hose on the rear? They are only $60 each, so it's better than the stealership...
Old Apr 5, 2011 | 08:51 PM
01tl4tl's Avatar
they are cheap because they have no vacuum boost to stiffen them under power
but==some years came with vac and some without
you need to get under the car and verify what you have
If you want to go cheap just plug the vac lines securely
ck our sponsoring dealers who cut us a major break on prices
Old Apr 5, 2011 | 08:53 PM
01tl4tl's Avatar
have the mounts been diagnosed?
the front fails all the time- followed by passenger side one
the rear is rarely bad unless its been a long time with the other 2 broken
Old Apr 5, 2011 | 10:13 PM
sbuswell's Avatar
I need 2 more gears
unless you poly fill them get vac assisted mounts or they won;t last long at all.
Old Apr 5, 2011 | 11:44 PM
grdprx's Avatar
Yes, all 3 engine and a trans mount were diagnosed bad. The rear was causing a vacuum issue with the engine also.
Old Apr 6, 2011 | 12:59 AM
01tl4tl's Avatar
ck out sponsoring dealers- for 20-30 bucks more you can get the right part and solve the vac leak
the vendor list is to the left of the Log Out box
your car must vibrate right now!!
Old Apr 6, 2011 | 09:25 PM
sbuswell's Avatar
I need 2 more gears
now would also be a great time to poly fill the front and side mounts and replace the stock vac assisted rear mount with an OEM rear. The tranny mounts aren't too expensive and are easy to replace. I'm actually going to replace my tranny mounts again this weekend with poly filled versions as one of mine is now torn in half. It's possible all 5 of your mounts are bad. Once one goes (namely the front motor mount) the rest will follow suit including the tranny mounts. All new mounts will make a world of difference.
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
juanrl
Sep 29, 2015 03:25 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
