MIN Cranking voltage
Old Oct 3, 2009 | 10:52 PM
MurdaZ's Avatar
so i had a problem with the neg battery terminal. was loose and i believe caused sluggish start ups
so i did the big three wit 1/0 gauge and it still does the problem.
so the only volt meter i have is my cap. when i try to start, the voltage drops to about 7-8.5 volts, then idles at 13.90--14.50 (cuz of my system)
when i use my starter it doesnt even crank. it turns on the lights, 1 crank then dies.
i forgot my notes, but what is ideal cranking volts? 10?
Old Oct 3, 2009 | 11:24 PM
friesm2000's Avatar
B A N N E D
proably needs a battery, they don't last forever
and the charging rate is fine some cars only do 13.8 with every off and NO SYSTEM
Old Oct 4, 2009 | 12:44 PM
fsttyms1's Avatar
You need a battery. There is more to the battery than just voltage. Bring it to a battery store or sears and have them load test the battery.
Old Oct 4, 2009 | 04:48 PM
Rajca's Avatar
wham bam thank you ma'am
i believe its 10.5 minimum cranking voltage. but like stated above, get the battery load tested.
Old Oct 4, 2009 | 09:18 PM
MurdaZ's Avatar
will do tommorrow, thanks guys, most likely targeted the batt since everything keeps getting reset....
btw good write up in the big three diy rajca....!
Old Oct 4, 2009 | 09:21 PM
Rajca's Avatar
thanks
Old Oct 5, 2009 | 11:05 AM
acutee's Avatar
Your battery could have a good voltage, but it may not have enuf crank amp. So, good voltage does not mean battery are still holding charge. The cells are parallelly connected; so if you have 12 cells, 10 of them died, the 2 cells left can still give you good voltage, but not enuf juice to crank. check your charging voltage, it has to be above 14volts.
Old Oct 5, 2009 | 06:41 PM
friesm2000's Avatar
B A N N E D
so if everything keeps resetting then it is DEFINELITY your battery cause it is not holding a charge anymore
Old Oct 5, 2009 | 07:24 PM
totaledTL's Avatar
Actually the cells would be in series, to add up to approx. 12v.
i. e., 2 cells in series = double the voltage.
2 cells in parallel = double the capacity.
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
acuratl26
Apr 23, 2020 07:30 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
4drviper
Sep 23, 2015 07:42 PM
HeloDown
Sep 8, 2015 06:51 PM
