MIN Cranking voltage
so i had a problem with the neg battery terminal. was loose and i believe caused sluggish start ups
so i did the big three wit 1/0 gauge and it still does the problem.
so the only volt meter i have is my cap. when i try to start, the voltage drops to about 7-8.5 volts, then idles at 13.90--14.50 (cuz of my system)
when i use my starter it doesnt even crank. it turns on the lights, 1 crank then dies.
i forgot my notes, but what is ideal cranking volts? 10?
You need a battery. There is more to the battery than just voltage. Bring it to a battery store or sears and have them load test the battery.
Your battery could have a good voltage, but it may not have enuf crank amp. So, good voltage does not mean battery are still holding charge. The cells are parallelly connected; so if you have 12 cells, 10 of them died, the 2 cells left can still give you good voltage, but not enuf juice to crank. check your charging voltage, it has to be above 14volts.
i. e., 2 cells in series = double the voltage.
2 cells in parallel = double the capacity.
acuratl26
04-23-2020 07:30 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
4drviper
09-23-2015 07:42 PM
HeloDown
09-08-2015 06:51 PM
