Metal Rub under Load - Front end
Old Jun 27, 2012 | 06:56 AM
dre271's Avatar
Unhappy Metal Rub under Load - Front end
I have been banging my head against the wall on this noise.
Car background: The car has 180K, new trans at 107K, and the original CV joints.
1) On acceleration, there is a mild metal on metal rub noise coming from the front of the car (only under load) from 0 - 15 miles a hour. I checked the engine mounts, all good. Not a clicking noise, but metal on metal.
2) If I coast down a hill in neutral, no noise. Only when in gear and accelerating.
3) I checked the suspension on the front, nothing loose, nothing worn.
4) I drained the trans last month again, nothing metal in the fluid and the shifting is perfect.
I am not sure if it a bearing in the trans or an inner ball joint.
Any help? Please?
Thanks,
dre
Old Jun 27, 2012 | 08:37 AM
dre271's Avatar
Solved -
Issue solved. Front Engine Mount. I service tech put the car in Drive while holding the brake down & pounding on the gas to recreate the noise. Now I just have to figure out how to replace the mount or pay $400 (labor & material).
Cheers.
Old Jun 27, 2012 | 10:42 AM
01tl4tl's Avatar
use our diy section and one of our dealer vendors that give a 30% cut off parts prices
that mount retails ~$150
they get to charge obscene labor for it too
diy 1.5-2 hours at casual pace and breaks
if you need help- see the regions link for areas, and ziners there
Old Jun 28, 2012 | 08:25 PM
dre271's Avatar
Thanks guys. The part is arriving Friday and I plan on doing the install Sunday. I will do a before after!
Thanks,
dre
TLDude876
Dec 28, 2016 03:18 PM
02tljj
Sep 11, 2015 12:37 PM
08 NBP TL
Sep 8, 2015 08:49 PM
