Black marker remover?
Old Jun 25, 2012 | 07:09 AM
MilwaukeeDave's Avatar
Yea so vandals hit my car last night. No apparent reason. Can someone tell me what will remove this black marker? Not sure if it's permanant or not. Can I use goo gone?? Here's a pic:
Old Jun 25, 2012 | 08:53 AM
JDTL-S2002's Avatar
Try a Mr. Clean magic eraser supposedly works on permanent marker. If not rubbing compound. Good luck!
P.S. you should find these a**holes and beat the brakes off 'em
Old Jun 25, 2012 | 08:56 AM
^i wouldnt use the magic eraser. thats abrasive!!
try rubbing alcohol, googone, or any of those firsT!
soap and water and elbow grease might take it out.
Old Jun 25, 2012 | 01:06 PM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
That sucks, At this rate the whole car will be repainted before you know it. Try running alcohol or goo gone. I would try just soap and water first to see how that affects it
Old Jun 25, 2012 | 01:49 PM
Alcohol. Solvent. Gasoline. None of them got it completely off there's still a shadow of it. Going to a detail shop for clay bar and buff out.
Old Jun 25, 2012 | 06:20 PM
suspaction's Avatar
Man that really sucks, so I guess it's the garage for your car in the future. If all that didn't work you could use polishing compound (not rubbing compound) with a buffer until that bit of tainted paint is gone, then use some wax to shine it and protect it. Hopefully it won't be too expensive to fix though good luck, oh and **** those guys!!
Old Jun 25, 2012 | 06:36 PM
Skirmich's Avatar
Go into a Car Wash that has Detailed Services and get a Wax... It should Remove it + Make your Paint look Brand New!}
The Way they did it make them look like some Kiddos, No cholo in his right mind would do that.. Vandalize = Break All your Windows....
Old Jun 25, 2012 | 09:53 PM
victus1's Avatar
WD-40 is safe to use on paint. But a clay bar will get it out, and safely.
Old Jun 29, 2012 | 10:56 AM
Needed wet sanding. Clay bar didn't work. Here's how it looks now:
Old Jun 29, 2012 | 11:00 AM
awesome!!
Old Jun 29, 2012 | 12:10 PM
What happened at the top of the drivers door?
Old Jun 29, 2012 | 12:44 PM
victus1's Avatar
Wow, what did you need to do, take off a layer of clear coat? What grit sandpaper did you use? And did you need to redo the clear coat again?
Old Jun 29, 2012 | 06:50 PM
The drivers door damage was there when I bought it. I'm guessing he fling the door open into something. It's on my to do list. I don't think he took much clear off and not sure as to what grit was used. Went to a good detail shop he charged me 40 bucks.
cycdaniel
Dec 17, 2019 10:58 AM
Oct 21, 2015 11:38 PM
coykiam
Sep 11, 2015 03:43 PM
