Master Cylinder Replacement DIY?
Old Jun 1, 2010 | 01:51 PM
irishTL's Avatar
Does anyone know of or have any DIY instructions for replacement of the master cylinder in a 2001 TL? I have searched this site but I haven't had any luck.
Old Jun 1, 2010 | 05:22 PM
01tl4tl's Avatar
its 2 bolts at the master cyl and 2 lines going into it
prefill and prebleed as much air out as possible
try internet seach or autozone or kragens for online diy
See any of my posting on correct and safe brake bleeding from there
did you ck our Garage/Diy sections on azine?
Old Jun 2, 2010 | 08:13 AM
irishTL's Avatar
I didn't check those azine sections specifically, but I did do a search in the Second Generation forums. I also went to a local library last night and made some copies of the DIY instructions from the Haynes manual for this vehicle. Thank you for the help!
Old Jun 2, 2010 | 01:30 PM
fsttyms1's Avatar
Its very easy. LIke said above. suck as much brake fluid out as possible, remove the 2 lines and place a towel under ot help catch the fluid dripping, remove the 2 bolts that hold it on. Then bench bleed the new one. reverse for install. Bleed brakes VERY good after. Bleed order as follows. LF, RF, RR, LR
Old Jun 2, 2010 | 09:11 PM
irishTL's Avatar
I've done a lot of work on my own vehicles, but brake bleeding is one thing that I have not done. What is bench bleeding?
cycdaniel
Dec 17, 2019 10:58 AM
02tljj
May 2, 2019 08:56 AM
Skirmich
Sep 15, 2015 06:41 PM
gqdabien
Sep 8, 2015 11:41 PM
ellisd03tls
Sep 8, 2015 04:17 PM
