Maintenance Required Light and Maintenance Schedule
Old Aug 23, 2013 | 03:05 PM
  #41
tjkazai's Avatar
2002 Acura TL
Originally Posted by fsttyms1
Pop the dash trim piece off and see if the trip reset switch is connected. If not connect the harness.
damn, simple ok I'll do that thanks!
Old Aug 23, 2013 | 10:26 PM
  #42
tjkazai's Avatar
2002 Acura TL
DONE!!!!!!
woooohooo, my dads friend is a mechanic and taught me so much lol, the maintenance is required after I plugged it in to the select/cancel
Old Aug 24, 2013 | 05:05 PM
  #43
3.2TLc's Avatar
Yeah, someone to guide ya along with your friendly local Ziner's .....the only thing better would be the Factory Service Manual for a back-up !!!
Old Aug 25, 2013 | 07:23 PM
  #44
03 tls nc's Avatar
Glad you got your switch hooked up and working how are you coming with the bolts in the t-stat housing and you inspection?
Old Aug 25, 2013 | 07:45 PM
  #45
tjkazai's Avatar
2002 Acura TL
I still have to fix the tstat bolt only 1 bolt is holding the housing down but no coolant is coming out, but I should really find out what bolt I need, any clue?
Old Aug 25, 2013 | 08:38 PM
  #46
03 tls nc's Avatar
I would be more concerned with getting the broken part out. Its more then likely going to be the same size and tread pitch as the other bolt that hold on the housing. Once you have the broken piece out then you can test fit one of the other bolts to confirm what you need.
Old Aug 25, 2013 | 09:22 PM
  #47
3.2TLc's Avatar
Talking Livin' on the edge....
Hey Tjkazai, are ya driving the car with just the one bolt holding the T-stat ? Ya really don't wanna take the risk of something happening which may jeopardize your car's cooling system.
Even if ya had the right bolt in your hand now, ya would still have to pull the T-stat's housing cover to remove the broken part of the original bolt.
So, just take the cover off again and with a bit of luck the old bolt may be broken high enough to get needle nosed vice grips on it to carefully remove. If ya still have the top part of the broken bolt head, compare it to the other side's good bolt once it's removed. You'll then know how much is left remaining of the threaded broken bolt within. If ya can't get on it, the next step would be to drill the bolt and try to use an EZout extractor, "PITA".
If ya are lucky enough to get the broken bolt out, make sure that the internal threads are good and not cross-threaded, otherwise you would need to possibly use a tap & die to chase and clean the bolt holes. Buy 2 new bolts and apply anti-seize before re-installing the cover.
Don't over torque the bolts !
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
PortlandRL
Sep 14, 2015 12:01 PM
datadr
Sep 12, 2015 09:12 PM
ahsm
Sep 9, 2015 08:35 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
