Lowbeam Bulb replacement DIY HELP
My passenger side lowbeams went out so i bought myself 2 new phillips d2r hid bulbs. I'm planning to replace both sides myself. Can anyone point me to a DIY guide? Thanks
Regional Coordinator (SoCal)
REMOVING YOUR BUMPER:
https://acurazine.com/forums/showpos...58#post1870075
HID REMOVAL:
https://acurazine.com/forums/showpos...24&postcount=2
HID REMOVAL:
it's really easy to do. you won't even need a torx #20 screw. just use a small flathead to loosen the screw for the dustcap. after that, push down on the retaining metal flip and push out all the way till the bulb is loose, then replace with new one, put the clip back on, and you're good to go.
^ why would you remove your bumper? Its isnt needed. The time it takes to do that for what ever reason you can replace the bulbs. Yes you can use a flat head but the security torx can be bought just about any where for a few bucks and makes the job easier.
fsttyms1 I just had my passenger low-beam go out and am not very mechanically inclined. You seem to be very knowledgeable on this topic and since you live less than 30 minutes from myself, I was hoping you'd be willing to help. I'd be more than willing to compensate you for your time.
I'm a new member fsttyms1 so it won't let me send you a PM or receive any I don't believe. If you would be willing to help me out please send me an email at jtheinz2@yahoo.com
Yeah i didn't remove my bumper when i replace my bulbs either
i wasn't thinking so i just found the DIY threads and pasted it here for him. and the flathead seems to work faster than the torx screw itself. i have both. the torx screw on the cap has a nudge in the middle , and the torx screw doesnt have a hole to fit that in .. thus i used the small flathead.
How do I contact you?
I don't have anyway of contacting you, so if you'd please email me I'd appreciate it. jtheinz2@yahoo.com
cycdaniel
Dec 17, 2019 10:58 AM
Skirmich
Sep 15, 2015 06:41 PM
