left headlight sensor.
Old Nov 5, 2010 | 03:11 PM
Simplydoesit's Avatar
alright my left headlight went out. i bought a new bulb and replaced the bulb, it flickers but still doesnt work. i checked the fuses and im getting 12volts on the male side that plugs into the headlight. So what i think is that it might be the sensor that senses if the light has come on. does anyone know the name of the little box that is attached on the bottom of the headlight? ill need to be replacing it.
Old Nov 5, 2010 | 10:25 PM
totaledTL's Avatar
Which bulb doesn't work, high or low beam?
There's no such sensor. The "box" under the headlight is the inverter for the HID bulb (low beam).
Old Nov 5, 2010 | 11:27 PM
the left, alright thanks...its my low beam so my box (inverter) theory might be correct.
Old Nov 5, 2010 | 11:49 PM
finalcross's Avatar
Yeah, if it flickers, it is most likely your ballast (inverter). Searching ballast will give you more results.
Old Nov 6, 2010 | 11:35 AM
01tl4tl's Avatar
if you had moisture inside the headlight lens- that drips down and out onto the ballast- which fries it
must fix headlight seal and replace ballast--
junkyard or aftermarket for different unit are best options
01tl4tl's Avatar
you should always replace bulbs in pairs--you will soon notice the differance in color and brightness
LoneRonin
Jan 4, 2016 01:03 AM
johnalfa
Nov 5, 2015 06:44 PM
rockyboy
Sep 29, 2015 12:05 AM
ripit
Sep 26, 2015 06:19 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
