Leak (i did search!)
Old Jan 3, 2008 | 09:43 AM
pizz419's Avatar
Wish it was dropped.....
Angry Leak (i did search!)
Ok after reading pages and pages after I did a search....no one seems to have a resolution to their trunk leaking. Some did state that it was due to either tail lights (passanger side) or the sunroof. Mine seems to be coming from the sunroof. Anyone having the same problem? I do see the plastic tubes coming down and the one on the passanger side seems to be loose. Not on the bottom but at the top. Im assuming this leads to the sunroof (duh ) but does anyone have a fix for this? I am lost! It has completely runied a $3000 custom stereo!!!!!!
someone please help!!!
Old Jan 3, 2008 | 10:00 AM
pizz419's Avatar
more info. car is not under warranty. i dont know if the bass had something to do with it leaking or not. i never had the stereo on in the rain bec i knew the trunk would bounce and cause it to leak around the seal. i have ordered another seal from acura. its freaking 10 degrees outside so i cant really pour water on it.
sorry for the long post but at this point im frustrated and need to complain. water meets electrical components=all effin bad!
oh its an 02 TL-S.
Old Jan 3, 2008 | 01:57 PM
fsttyms1's Avatar
You will most likely have to pull the head liner down to gain access to the drain hoses to see if they are attached or where its leaking.
Old Jan 3, 2008 | 09:18 PM
pizz419's Avatar
thanks for the info! i have never pulled the one off on this car. have on other cars. any good ideas on how? just pull the clips and let it come down??
Old Jan 4, 2008 | 12:20 AM
fsttyms1's Avatar
yea pretty much. Remove the sunglass holder, visors and clips, and remove the rubber trim ring that goes around the sunroof opening.
Old Jan 4, 2008 | 07:16 AM
pizz419's Avatar
ok thanks. ill do that this weekend. its gonna be warm for 2 days or so then drop back off. i will take pictures so i can maybe show people how i fixed my horrible trunk leak.
Old Jan 7, 2008 | 02:24 PM
pizz419's Avatar
oke dokie. found the leak. it was a bad trunk seal. also there were a few gaps (looks like it had been in an accident, im the 2nd owner). so i put in the new seal and layed a healthy ammount of silicone caulk around the seal and any other place where it might leak. found this grey silicone and it matches my paint fairly well. its supposed to rain pretty good tonight so ill let you all know if there is any more leaks. if not. ill post picts of where i put the silicone....
love the site!! if i didnt find this site my dumba$$ probably would have taken it to the dealer.
Old Jan 7, 2008 | 04:33 PM
fsttyms1's Avatar
Old Jan 9, 2008 | 08:56 AM
pizz419's Avatar
so. final test was last night. rained really hard. checked this morning....NO WATER!!! Now time to rebuild my stereo...
Mike734
Dec 10, 2021 01:25 PM
08KBP_VA
Oct 22, 2019 01:55 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
Avenger411
Oct 11, 2015 03:53 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
