knocking sound
knocking sound
heres my problem. just recently when I was on my way home from work, I noticed a small knocking sound( or a tick) as if a bolt or something is rolling back and hitting something everytime i accelerate from a dead stop. You barely notice it unless you really pay attention. I then took out the stuff in my glove compartment and the sound was still there. recently I was at the dealership getting some service done and I had it checked out. when I talked to the tech, he said when he went for a drive, didnt notice anything. I had gone over every inch of the car while it was up on the hoist and I see nothing out of place. Seeing as how I never abuse the vehicle and avoid potholes and big puddles, should I worried?or is it just the typical brake squeak or noises as common members have here on the forums?
its got 78000KM's on the car. i noticed the sound 2 days before going to the dealership to get some stuff done. its coming from the front passenger side. its almost like a little "tick" or knocking sound. its goes away once its moving. I only notice it when im accelerating from a dead stop. sometimes it happens sometimes it doesnt. i have pressed down my window and listen once i accelerate for a bit but i cant find the cause. could it be that im crazy or is it just my imagination?
are the castle nuts on your control arms tight? i recently had a similair sound and it turned out my upper control arm's ball joint needed to be just tightened up a little. I t was just loose enough to cause the ball joint to jump up and down on stops and starts.
hmm sounds like a possibility. because when it was up in the air at the dealership, the control arms, tie rods, and balljoints seemed all tight and good. im probably gonna have a look at what you said above chris. so really if that is the case just tighten it and im good? like when it comes to this car im pretty anal in regards to keeping the car clean and running properly. surprised that even a little problem can be overlooked. if that isnt the case, any other alternatives?
It can't hurt to grab your socket and just check. You don't even need to take off the tire, just reach in over it and make sure its tight and not moving when the weight of the car changes, like stopping ir taking off. Mine was just loose enough to let it rock and make noise. If not grab onto your sway bar while there and see if that moves at all-
noises are often found with a mechanics stethascope- 5-10 $ at parts stores
It has a long point tip probe (like a 12v test light on bigger scale)
you place tip against the outer housing of any bearing like the ps pump- alternator or ----the AC belt tensioner pulley
thats a popular one to wear out- starts with light ticking- almost like valve noise, but just a bit irregular beat to it, gets worse until audilble with hood closed
if click click click- open windows to listen to front wheel area better,
from dead stop in D5 turn steering wheel full left and gently roll forward- nothing?
try the other direction click click click? CV axle bearing is most likely the problem
acura would have checked the normal things like broken suspension, and you would think they checked CV joints but you dont know unless you talked directly with the tech who did the work
I would start listening to things with the stethascope.
Launching to listen for cv noise? thats not the test I asked you to perform
SLOW- no throttle- release brakes and roll forward- with full wheel lock-- from a dead stop- listen
The insurance sign is to keep the masses who would walk in front of a car or stand under a life being lowered- out of the shop
You are allowed in when invited- and accompanied by shop employee
Stethascope the ac pulley and the valves- you will hear rythem or not- not is bad
ok so the sound came back to haunt me "-_-". i found out its coming from the brakes on the front right wheel. is that normal? its like a clicking sound is heard right when i release the brakes and begin to accelerate.
mlody
12-04-2019 02:11 PM
DerrickW
11-15-2015 05:52 PM
STL TL-S
09-23-2015 08:52 PM
