Key F.O.B. Programming Nightmare
Old Dec 9, 2005 | 05:04 PM
Ryons02TLTypeS's Avatar
Talking Key F.O.B. Programming Nightmare
I have a problem... I orginally got my car w/o the remote. The dealer where i bought my car got it for me.. Tried programming it with directions that i got from 3 different places... Didn't work. I took the battery out for about 24 hours 2 times... Still didnt work.... I dont know am I doing something work???
Please let me know somebody........
I would greatly appreiciate it..
Thank You....
Old Dec 9, 2005 | 09:44 PM
trueweb's Avatar
First, you have to make sure you have the correct remote for your car. Has this remote ever worked with the car? If not, perhaps it's the wrong one.
Check eBay for remotes and see what FCC IDs they have on them for the same model year as your car. I know they all have the same ID for certain year cars.
Taken directly from the Factory Service Manual for '99-'03 (This worked for me setting up two new remotes)
1. Turn the ignition switch ON (II)
2. Within 1 to 4 sec. push the transmitter lock or unlock button with the transmitter aimed at the receiver in the passenger's multplex control unit.
3. Within 1 to 4 sec. turn the ignition switch OFF.
4. Within 1 to 4 sec. turn the ignition switch ON (II).
5. Within 1 to 4 sec. push the transmitter lock or unlock button with the transmitter aimed at the receiver in the passenger's multplex control unit.
6. Within 1 to 4 sec. turn the ignition switch OFF.
7. Within 4 sec. turn the ignition switch ON (II).2.
8.Within 1 to 4 sec. push the transmitter lock or unlock button with the transmitter aimed at the receiver in the passenger's multplex control unit.
9. Within 1 to 4 sec. turn the ignition switch OFF.
10. Within 4 sec. turn the ignition switch ON (II).
11. Within 1 to 4 sec. push the transmitter lock or unlock button with the transmitter aimed at the receiver in the passenger's multplex control unit.
12. Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec., push the transmitter lock or unlock button again. The keyless receiver's now in the programming mode. You must push transmitter lock or unlock button of the first transmitter again program that transmitter.
13. Within 10 sec., aim the transmitters (up to three) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation with the new code(s).
Old Dec 10, 2005 | 12:55 AM
No I never used it with the car before. I bought the car w/o it.. But I do have the right remote, the FCC number is correct...
But pointing it at the passenger's multiplex control unit... I dont know where that is, is it the glovebox or something.....
Old Dec 10, 2005 | 12:59 AM
But other than that thank you... I will try it 1st thing in the morning....
Old Dec 10, 2005 | 11:25 AM
trueweb's Avatar
I don't know where the "multiplex control unit" is either. I suspect it's up under the dash somewhere. I really don't think that's so critical. I just quoted directly from the factory service manual.
If you're sitting in the car you should be close enough that the signal from your transmitter gets to the receiver.
Let us know how it goes!
Old Dec 11, 2005 | 03:43 PM
Well i found out where the mulitplex unit is... I seen a diagram, and i was pointin the fob to glovebox... Tried 3 times, no luck anytime... I seriously do not know. I have the right remote and shit. I really don't know. How much do you think ACURA would charge to this....???
Old Dec 11, 2005 | 06:35 PM
trueweb's Avatar
My car is a 2003TL-S, but I'm pretty sure '02 and '03 are identical in just about every way.
The FCC-ID on my remote is:E4EG8D-444H-A.
I have both memory 1 and 2 for my car and I bought both of them on eBay. I used the exact instructions listed above and it worked. It did take me a few tries to get all the timing right. I also remember there was some strangeness with the last few steps, especially when programming two remotes.
I wonder if key 2 cannot be programmed without key 1 or something like that. I'm just making guesses right now. I would think not, but anything is possible.
Are you sure the batteries in your transmitter are good? Perhaps you should replace them anyway...
Old Dec 12, 2005 | 09:34 AM
ABP-TLS's Avatar
Wifes Car
I had problems with my 03 i had the remotes sitting on the top of the horn when i hit the buttons that was the only way it worked
Old Dec 12, 2005 | 10:05 AM
i will try this again. The batteries are good cuz the led lights ups....
Old Dec 16, 2005 | 09:17 PM
littlewillis's Avatar
Used those steps to reprogram a KeyFob bought on Ebay (for $6.99 no less) and the steps worked LIKE A CHARM!!!!! Bought 02 TL 3 weeks ago, only came with #2 KeyFob... Now, both are working BEAUTIFULLY!!! Thanks for the help.....
Old Dec 20, 2005 | 01:04 AM
nah its the right 1 , imma try again and see whats up...
Old Dec 23, 2005 | 04:05 PM
no help..... didnt werk i dont know... i have everything right.... i dunno whats going on
Old Jan 12, 2006 | 11:13 PM
MARXMAN's Avatar
Hey Guys,
I've been trying all night with these remotes and it's not working. Two questions:
1. Does it matter what key you use ? Because I only have the valet key right now
2. The numbers on the remotes match my old ones in every way, BUT there is no label on each as to what number it is. Seat 1 or Seat 2...I says something about a company and then "Japan" underneath where that label should be. Should it still be working ?
Mark
Old Jan 15, 2006 | 05:31 PM
93Miata's Avatar
You probably have the wrong remote if you don't have the memory 1 or 2 posted on it. I don't think you can get the non-memory remotes to work on the memory seat cars.
I found them here cheap for the 02:
https://www.thepartsyouneed.com/disp...hg?productId=4
Old Jan 15, 2006 | 08:37 PM
hMMM interested.... imma take a look into that..... Thanks
Old Jan 16, 2006 | 11:28 PM
MARXMAN's Avatar
Thank You...anyone have any idea what these remotes are for ? The ones with no seat program
Mark
Old Jan 19, 2006 | 12:40 AM
wilp99's Avatar
im pretty sure the ones without the seat option works too. i just bought 2 from ebay for $14 each and programmed them both at the same time.. i have my older 2 remotes still if anyone wants to buy them. (i replaced them cause they are worn but they work good still) oh yea they have seat option 1 and 2.
Old Jan 20, 2006 | 01:01 PM
Im getitn the new remote today... Well will see ifd therse directions are good...
Old Jan 21, 2006 | 07:13 PM
MARXMAN's Avatar
Hey...If anybody knows what these remotes with no Seat Programs are for pls let me know. If they are of any use to you, you can have for the same thing I paid for them...$20 plus shipping for both. At least somebody can get some use out of them.
Mark
Old Jan 22, 2006 | 03:01 PM
Werks like a charm.... That was the BS about them, it didnt have MEory 1 or 2 on the previous 1..... Programmed it in 1 min.... Werked beautifully..... Thank You Acur World....
Old Apr 28, 2006 | 05:29 PM
fyamin's Avatar
I have been trying this for two day on my 03' TL, both fobs are original which came with the car, none of the equipment is changed, only the battery was unplugged
now both fobs don't work, the navi and radio work after I entered the codes
I have been trying these instructions but doesn't seem to work for me.
Don't kow what to do
Old Aug 21, 2009 | 03:12 PM
dgdmn's Avatar
The "Gotcha"
I just ended about 20 minutes of futility trying to follow those instructions. I ignored one very important part. "Remove the key." Evidently the programing does not finish until you remove the key.
Hope that saves you some time.
Old Aug 22, 2009 | 12:52 AM
totaledTL's Avatar
Umm... that was over 3 yrs. ago....
soupi
14
Nov 15, 2015 11:15 AM
eastcoastguy
Oct 29, 2015 03:00 PM
joflewbyu2
Oct 8, 2015 11:16 AM
malvothegreat
Sep 29, 2015 12:38 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
