Jacking car for stands
Old Mar 30, 2018 | 03:02 PM
Cecallred's Avatar
Question Jacking car for stands
I see where you should only jack the cars on the side, under the door points made for it. No-brainer there. However, the area for that isn't very long (wide?) so how do you get a jack stand under there to remove the jack itself? Sounds weird, I agree, but I'm really curious. I once tried to jack the front up by using a point in the front center. It dropped off. Not happy with that as you can imagine.
Good weekend guys
Cec
Old Mar 30, 2018 | 03:50 PM
Chojun's Avatar
In the rear, there's a hook/loop attached to the gas tank that you can jack on. It doesn't seem right but that's the designated spot in the rear.
In the front there's a flat spot on the lower front frame that you should put your jack on.
I'm assuming you're using a floor jack. Don't forget to chock your wheels too.
Old Apr 2, 2018 | 10:29 AM
Cecallred's Avatar
I'll look closer on the front. I see the jack stand locations (yes, using floor jack) The other must be hidden under the rock shield which I haven't removed. OR I just missed it.
Cec
Old Apr 2, 2018 | 11:15 AM
it has a marking on it.. i think it's an arrow pointing to it. or rather a square, indicating it's the jack point.
1997AcuraCL3.0
1G CL Problems & Fixes
May 27, 2016 12:28 AM
t3hanarchist
Nov 22, 2009 10:22 PM
Tennisjon2002
Aug 1, 2008 11:34 PM
some1
Apr 13, 2002 09:36 PM
