Infamous Battery Drain..
Old Jul 16, 2013 | 07:45 AM
mr_grand_prix's Avatar
Hey everyone,
I am having the infamous battery drain on my TL. I just recently got the vehicle about a month ago.
To give you a little bit of history, it just started two weeks ago.
When we came back from vacation and the car sat for 4 days, my TL was completely dead but interior lights were on when opened the door but were dim.
I thought for sure this was the bluetooth module draining the battery. I disconnected the HFL and removed it completely. I also noticed when I removed the HFL that the module was reallly HOT! I had the battery charged at Autozone and hooked it back up and it was good to go for a couple of days until yesterday morning it was dead in the morning. I had the battery charged again and it worked fine.
This morning I got in the car and noticed it was kinda slow to start up like the battery was draining again.
I am kinda at a crossroads bc I am thinking maybe the battery just needs to be replaced or something else is draining it. Any thoughts, I just hope it is not something bigger.
Appreciate the feedback guys
Gus
Old Jul 16, 2013 | 08:19 AM
check the battery with a multimeter.
when the car is off, the battery should give off 12v.
if less than 12v, your battery is no good and a new one is needed.
the infamous battery drain is the HFL.
that does not mean that other things are not bad...you'll just need to check them.
we, the internet, cannot check them for you.
Old Jul 16, 2013 | 10:11 AM
Can someone move this to the 3rd generation TL Problems and Fixes?
Thanks!
Old Jul 16, 2013 | 10:15 AM
^its okay, you'll get the same answers here too.
you'll need to figure out where the draw is coming from.
or if your battery is low.
moving it to another section wont magically solve your problems.
Old Jul 16, 2013 | 10:20 AM
oh really it wont???.. no one on here has a magic wand?...hmm... LOL
I know that, I just want to correctly place my thread in where it belongs...if it doesnt matter then there is no need to have specific generation groups... am i right?
but thanks for the help thus far!
Old Jul 16, 2013 | 10:22 AM
^well, the HFL parasitic loss is pretty well documented.
if one were trying to find a thread on it or battery drain, they wouldnt have to look far...as you found the information yourself!
this would be the 1000000000000000000000000 thread on it.
i digress.
Find out if your battery is good, by taking it to autozone or the like to have it tested.
or you can do it on your own with a multimeter by seeing if it holds 12volts when the car is off.
this is the first thing I would check..
Old Jul 16, 2013 | 10:25 AM
battery has already been checked and told me it is a good battery...but in my eyes could have some dead cells there...
thats where the confusion is. I could take your advice and check what the draw is from the battery as well.
I dont mind buying another battery just hate for it to happen again if i can prevent it on the new one.
Old Jul 16, 2013 | 10:27 AM
^if you buy a new battery; it will come with a warranty.
if it drains over night, take the new battery back!!!
the sears diehard platinum series is pretty good.
I bought a battery from walmart. and its been strong for 2 years now.
the acura oem batteries suck.
Old Jul 16, 2013 | 03:30 PM
Car came with a autocraft gold battery. Sticker had 7/11
Old Jul 16, 2013 | 03:33 PM
^might be time to change.
Old Jul 16, 2013 | 09:29 PM
So I just bought a new battery. HFL has been disconnected already.
I am curious to see what the result will be in the morning when I start it up.
When I removed the HFL it was working fine but extremely hot.
Anything else I should be checking if this new battery doesn't work?
Old Jul 16, 2013 | 09:31 PM
by your description:
it sounds like a battery issue.
if it started right up with the new battery; I'm pretty sure you got it!
Old Jul 16, 2013 | 09:46 PM
I hope so but the battery I just replaced had got a full charge from autozone and they indicated it was a good battery so I'm a little hesitant to celebrating right now.
Just hope the new one corrects the issue.
One thing I do notice is after I removed my HfL..when I go to info on my dash and select Hands Free Link it says booting up. Is this normal to say even though I removed the module?
Old Jul 17, 2013 | 07:34 AM
its tomorrow already.
in for results..
Old Jul 17, 2013 | 09:17 AM
Ok so I woke up this morning, started the car and it started right up. No issues at all.
So for now it looks like my issue is resolved.
I even stopped for gas and everything is fully powered.
My question is, how can my old battery be draining if Autozone indicates its a good battery and is charged.
Was it on its way out?
Old Jul 17, 2013 | 12:23 PM
sauceja's Avatar
Desert Life Sucks!!
Its possible. I just replaced a battery that had false hfl symptoms. It was just draining. Couldn't keep its charge. Still showed good.
Replaced battery, no issues since.
MetalGearTypeS
Aug 29, 2016 08:28 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
steve
Sep 30, 2015 09:23 PM
mars
Sep 28, 2015 11:03 AM
jmaxima03
Sep 27, 2015 10:22 AM
