Ignition coils by HAMBURG-TECHNIC
Old Apr 3, 2010 | 02:49 PM
Kobazi's Avatar
Cool Ignition coils by HAMBURG-TECHNIC
Has anyone used coils made by HAMBURG-TECHNIC? I was thinking of buying of a set of Ebay.
Old Apr 3, 2010 | 03:09 PM
fsttyms1's Avatar
what for? you have problems with yours?
Old Apr 3, 2010 | 03:51 PM
Kobazi's Avatar
Yes..it's mis-firing. I bought one coil and tried to isolate but...it seems it might be more than one. I already replaced the spark plugs with a set of NGK Iridium.
I'm looking at around $450 (5 coils) here in Toronto, Canada. I was trying to cut cost and came across ebay on the HAMBURG-TECHNIC coils.
Old Apr 3, 2010 | 04:19 PM
fsttyms1's Avatar
they are like 50 bucks a piece at the dealer.
http://www.acuraautomotiveparts.org/...catdisplay.jsp
Old Apr 3, 2010 | 04:26 PM
Kobazi's Avatar
Dang...they only ship within the US and Puerto Rico...and I was so excited
Old Apr 9, 2010 | 08:26 AM
spiro's Avatar
I have six on an engine with 53000 km, if you would like to borrow them to isolate your problem you are welcome.I am in toronto .
Old Apr 9, 2010 | 11:31 AM
fsttyms1's Avatar
If you bought one and it still didnt work you may have a different problem. Try taking your injectors out and cleaning them.
Old Apr 12, 2010 | 08:32 PM
Kobazi's Avatar
Just like you said, I have to move to the injectors. I changed all 6 coils and the issue persist.
Old Apr 12, 2010 | 08:47 PM
Kobazi's Avatar
Does anyone know if there are a DIY on cleaning the injectors?
Old Apr 12, 2010 | 09:00 PM
fsttyms1's Avatar
Not that i have seen. Take the intake mani off, unplug the injectors, remove the fuel rail and they should come out. Clean them in fuel injector cleaner (soak them for a while). When putting back together put some Vaseline on the rubber O rings so that they slip into place without tearing or moving.
Old Apr 13, 2010 | 06:54 AM
totaledTL's Avatar
Make certain to bleed off the pressure first!
Old Apr 13, 2010 | 12:47 PM
fsttyms1's Avatar
Acura604
20
Aug 5, 2017 12:55 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
malvothegreat
Sep 29, 2015 12:38 AM
h22lude
Sep 27, 2015 06:22 PM
