Ignition coils by HAMBURG-TECHNIC
what for? you have problems with yours?
Yes..it's mis-firing. I bought one coil and tried to isolate but...it seems it might be more than one. I already replaced the spark plugs with a set of NGK Iridium.
I'm looking at around $450 (5 coils) here in Toronto, Canada. I was trying to cut cost and came across ebay on the HAMBURG-TECHNIC coils.
If you bought one and it still didnt work you may have a different problem. Try taking your injectors out and cleaning them.
Not that i have seen. Take the intake mani off, unplug the injectors, remove the fuel rail and they should come out. Clean them in fuel injector cleaner (soak them for a while). When putting back together put some Vaseline on the rubber O rings so that they slip into place without tearing or moving.
Acura604
20
08-05-2017 12:55 AM
