if anyone is on right now...!!!
Old Feb 10, 2011 | 06:49 PM
slvrcrunch's Avatar
how effective would a cleaning be by just removing the IM cover? my curious hands took the cover off and it is NASTY IN THERE! hopefully i didnt just screw my self over with the gasket. i was as careful as i could be with it so i should be ok. anyways. looking for a response asap. thnks guys
Old Feb 10, 2011 | 06:51 PM
Karanx7's Avatar
Unregistered Member
Clean it. There's a DIY for the EGR valve in the DIY section. If it's already open and dirty, you might as well clean it. The EGR valve will clog up, and can cause problems. Just make sure that it is ABSOLUTELY dry before you put it back on.
Old Feb 10, 2011 | 06:53 PM
slvrcrunch's Avatar
i thought i had to take the complete manifold off to completly do the cleaning. i will do what i can. u think if some of the crud fell in it would burn off pretty quickly
Old Feb 10, 2011 | 06:58 PM
Karanx7's Avatar
Unregistered Member
Edit: Nvm, I'm confused...
You just need to take the top part of the intake manifold off to clean the EGR.
Here's a couple links:
https://acurazine.com/forums/showpos...67&postcount=8
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-thermoblok-spacers-install-egr-cleaning-615644/
Old Feb 10, 2011 | 07:10 PM
slvrcrunch's Avatar
one more question for u. do u think its safe to reuse the gaskets. if so i will just go ahead and do the whole thing now that i know it needs it. new gasket is around 40$, said srew that. thanks for the help btw
Old Feb 10, 2011 | 07:37 PM
01tl4tl's Avatar
you remove the entire intake manifold to clean it, not just the cover that lets you see the crud
DO NOT poke crud thru the holes with manifold installed on the engine and expect no bad things to happen!!!
The main place you are cleaning beyond the ports- is the actual length of the passage from one end to the other
Old Feb 10, 2011 | 09:29 PM
fsttyms1's Avatar
And as long as you dont bend the gaskets you can reuse them.
Old Feb 10, 2011 | 11:11 PM
slvrcrunch's Avatar
thats why i was curious about just the cover. well i cleaned it up and tried to clean the main port as much as i could without getting cleaner or crud in it. the skinny runners behind the gasket were completely clogged. looked like a solid piece. runs a little smoother now, but i know im not getting the full effect. ifi can reuse the gasket ill go ahead and run the IM thru the parts cleaner at work, just not paying $40 for a new gasket. thanks for all of the help
Old Feb 11, 2011 | 06:40 AM
totaledTL's Avatar
Can you make your own from a sheet of gasket material?
Old Feb 11, 2011 | 08:38 PM
slvrcrunch's Avatar
i cant personally. dont know about anyone else. would be nicve to have all reuseable metal gaskets though
Old Feb 11, 2011 | 09:04 PM
01tl4tl's Avatar
its a complex gasket--thats why its so expensive
note- installing it upside down happens- looks right but its not
always ck against the upper cover- it blocks a port there if on wrong
Occurs when removed for service work--gets flopped on bench...
you cant use metal in certain places and expect the seal you need
thats why there are rubber cork fiber and metals of many types are used for gaskets
