How to take off the oil Pan on 99 TL
Skeet Skeet Skeet
like the topic says i want to know how to take off the oil pan off a 99 TL i took all the 10 mm bolts out and the two 14 mm bolts but i cant get it off
Skeet Skeet Skeet
got it off but by time i got to the dealer to get some Honda Bond since it doesn't use a gasket they were closed so i have wait until Tuesday to put it back on
bummer. you could use another liquid gasket found at autoparts stores so you dont have to wait till then
Skeet Skeet Skeet
A water main broke in an underground parking deck and water came up to the doors so i drain the oil and took off the oil pan just to make sure there wasn't anything in there. Its off now nice and clean ready to go back on tuesday when the dealership opens up because i dont wanna use anything else except honda bond to put it back on...
Skeet Skeet Skeet
Originally Posted by sbuswell
that's a good reason then. Did your engine suffer and water damage?
well, your right about using the honda-bond..very good stuff.
but there was absolutely no reason whatesover to remove your oil pan. It was a complete and utter waste of time unless you were doing it for self amusement.
Have fun, though!
and tighten the 10mm nuts before the bolts in a cris cross pattern.
IBankMouse
06-13-2020 12:53 PM
