TL ecu problem
Old Dec 20, 2005 | 07:23 PM
honda_inspire99's Avatar
Skeet Skeet Skeet
TL ecu problem
this question might sound stupid but anyways i'm tryin to narrow down the problem with my 99 TL. IF the ECU got submerged in water which is more than likely damage, will the car even turn over or start after that? I my GSR when the ECU is out the car turns over but wont start so i would like to if the TL is the same way thanks
Old Dec 20, 2005 | 07:37 PM
Edward'TLS's Avatar
6G TLX-S
Even if the ECU survives the water bath, corrosion will eventually set in and ruin the circuit board and electrical contacts, thereby causing intermittent faults or total failure.
Old Dec 20, 2005 | 07:43 PM
Skeet Skeet Skeet
k thanks i do notice some corrosion on some parts inside the ECU so i hope thats my problem cuz i found one for $150 at a local junk yard. I would still ike to know if the car would turn over with a bad ecu or with the ecu?
Old Dec 20, 2005 | 09:26 PM
fsttyms1's Avatar
well if its bad and triggering the imobilizer it wont crank over
Old Dec 21, 2005 | 07:42 AM
Skeet Skeet Skeet
if i get a another ecu will it affect the imobilizer system?
Old Dec 21, 2005 | 10:53 AM
Skeet Skeet Skeet
now the car is turning over but it wont start when i bridge the starter by putting a piece of wire on the little clip on the starter and touch the positive terminal on the battery.
Old Dec 21, 2005 | 02:34 PM
Edward'TLS's Avatar
6G TLX-S
You'll also need a working ECU to supply the properly timed ignition and fuel injection pulses to the engine for it to run.
Old Dec 21, 2005 | 04:12 PM
fsttyms1's Avatar
:agreed:
Old Dec 22, 2005 | 01:16 PM
Skeet Skeet Skeet
The key is now turning over car but its not starting. The key started working once i took off the RSX key and the spark plug gap tool off the key chain so now i need to figure why its not starting up
Old Dec 22, 2005 | 04:09 PM
fsttyms1's Avatar
use just teh TL key, take every other key off. It sounds like the emobilizer is going wacky
Old Dec 26, 2005 | 12:26 AM
loud_whispers's Avatar
does the green immobilizer key on your dashboard stay lit/blink or go off when you try and start the car?
Old Dec 26, 2005 | 12:28 AM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
If it blinks when you're starting the car, it doesn't recognize the key. We went over this in your PMs to me. If you have other chipped keys on your keychain that can cause problems.
Old Dec 26, 2005 | 01:05 PM
Skeet Skeet Skeet
like i said in the above post i took the rsx keys of the key chain and it worked...thanks for all you guys help
TypeS860
Jan 10, 2026 11:11 AM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Skirmich
Oct 1, 2015 12:59 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
