how to remove headlights by yourself
Old Aug 5, 2011 | 01:41 AM
dianaglez's Avatar
how to remove headlights in a 2000 ACURA 3.2 TL without damaging sensible components
Old Aug 5, 2011 | 02:13 AM
01tl4tl's Avatar
is that a question or the start of a DIY?
here is our diy master list to give you some ideas
https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
the front bumper cover is bulky but manageable, helps to have buddy when sliding it back on
use a large cloth on ground to protect paint
otherwise you can go thru the engine compartment, removing things as needed for access just to bulbs--
note: tricky to get the arm that locks bulb in place.. working blind
so the first question is: are you replacing bulbs only-due to age failure (pink/purple tint at startup of light)
or installing a new aftermarket `ballast kit` because you have moisture inside the lens
which killed the other parts
blacktsxwagon
Oct 27, 2015 10:12 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
rockyboy
Sep 29, 2015 12:05 AM
Desert Ridge
Sep 27, 2015 02:37 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
