How can I open my door?
I have a 99 TL.
The driver side rear door outside door latch has stopped working. So I was able to open the door from the inside. But in messing around with it I accidentally turned on the child lock and closed the door. Now I cannot open the door from the inside or the outside.
Any suggestions on how to open this door?
You will have to remove the lower seat cushion but you can still remove the door panel. It will be tough to get the bottom out but it will come with some muscle and determination. It happened to me (minus the child lock) the lock/latch mechanism rusted and neither door handle would open it. Once removed from the car soaking it in PB Blaster and moving it by hand freed it and a good lubricating its still working.
I have a 99 TL.
Hey UNcatTech.....when and if ya figure this out, please post back with how ya actually fixed the problem. Thanks !!!
I'm thinking I'm going to have to take the door panel off, somehow.
I still can't figure out what I was thinking when I moved the child lock switch.
There has to be something left of the original handle. Can you sand it to roughen it up, then expoxy/JB weld something on to it to open the door?
Then replace the handle with an appropriate one. Just have the part on hand, you don't want to shut the door before you replace it.
mlody
Dec 4, 2019 02:11 PM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
