Foam in coolant?
Perhaps your last oil change used a strong cleaning detergent ? Doubt it, but...
How does the oil appear ? Any white smoke from the exhaust ? How's it running ?
If the coolant is milky and foamy, chances are that ya have a leaky head gasket, IMO.
Have the cooling system pressure checked and perhaps a cylinder leakdown test.
Could possibly be just a minor leak starting to develop ?
Is there only some foamy residue on the rad cap opening or is the coolant also discolored and foamy ?
Best to get it checked before it may get worse. It'll put your mind at ease to know for sure.
Yeah the coolant looks fine, but I guess I'll get it looked at sometime soon to be safe. Thanks again
The '03 TL's didn't have a tranny cooler, the '99 models with the older 4 speed AT's were the last to have an AT cooler from the factory.
The best thing to do if one suspects a leaking head gasket is to have the cooling system pressure checked and perform a cylinder leakdown test.
There's no AT fluid cooler built into the radiator? I thought my 01 CL had it...
I'm revising my diagnosis to say that the foam could just be the result of low coolant, so let's hope for that!
I'm away from my precious Amber, so I can't check.
Conceptually I like the the mechanical simplicity of the stick (like my 90 Legend coupe), but these days I am grateful for my lazy auto 80% of the time. And nowadays knowing an Accord or Odyssey AT swap is a real option, I can sleep again!
I'm using a yellow colored one, so it's not too discolored. But I still haven't been able to get anything checked since I've been busy but I'm still not having any over heating issues so I'm hoping it's something easy/small
This is the coolant I used http://mobile.walmart.com/m/phoenix;...e-Mix/16928010
http://answers.yahoo.com/question/in...6084146AA7Ogzi
I'm thinking that it was foamy due to it sucking in air while there was nothing in your reservoir.
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
