Hot air or Cold air....no in between??
Old Oct 6, 2010 | 07:46 AM
brad9101's Avatar
4th Gear
Help...I have searched this for several days but have not found a definitive answer for my problem...I have a 2003 Acura TL...I can only get very cold air at 60 or very hot air at 90...I have checked the engine bay and the valve will only move to fully open or fully closed...I have looked under the glove box and it would appear all the little parts move as they should...from reading, someone mentioned a heat control mixer is the problem...Is this so? How do I check to make sure thats it? How do I repair it? I know that I can just turn it to 90 and then back it down but my wife drives this car and I would prefer to get it working normal again...Thanks for the help!
Old Oct 6, 2010 | 11:53 AM
jdjohn84's Avatar
2003 TL-S w/Navi NBP
Do the self-diagnosis function to confirm the problem.
1. Turn ignition to ON(II) position.
2. On your climate control buttons, press and hold the AUTO and OFF buttons at the same time, and hold for one minute.
If there is a problem, one of the segments on the temperature readout numbers will illuminate, alternating flashing between '88' and one of the segments. Report back here with which segment, and someone can lookup the code. The bottom segment on the left side would indicate a problem with the air mix control linkage, door, or motor.
Old Oct 6, 2010 | 01:27 PM
HosTL Moderation's Avatar
AM Flakes still Drippin'
^ Wow really? I am still learning tricks about this car it seems like every other day. Thanks
Old Oct 6, 2010 | 02:26 PM
mrlee727's Avatar
7th Gear
I have the same problem in my 99 TL...I can only get very cold air at 60 or very hot air at 90 no in between. I also have a problem that may be related...when I turn on the front defroster I get air but not from the windshield vents. As a matter of fact, the blower will not engage any vents except for the dash vents. No defrost, no floor air...nada! It may be related. Any Ideas on what I should be looking for? I checked the fuses and they all seem to be ok...not fried.
Old Oct 6, 2010 | 05:50 PM
brad9101's Avatar
4th Gear
Thanks for the help and the responses. I did the test...so the dash blinked 88...the mark was made in the first of the two eights...it was the lower right vertical line of the first eight...Does anyone know what this means? Thanks again!
Old Oct 6, 2010 | 07:52 PM
brad9101's Avatar
4th Gear
I have found it to be code "I" if that helps anyone help me...
Old Oct 6, 2010 | 09:10 PM
01tl4tl's Avatar
try a google search for codes, or a search with any engine using:
climate control codes + TL+ acurazine.com
Old Oct 6, 2010 | 09:45 PM
jdjohn84's Avatar
It is indeed 'I', which is: open in the air mix control motor circuit. Sounds like you need to replace your control motor.
Old Oct 6, 2010 | 09:48 PM
jdjohn84's Avatar
Do the same self-diagnostic test, and see if you get any indicator segments coming up.
Old Oct 7, 2010 | 11:02 AM
mrlee727's Avatar
7th Gear
Ok, I did the test...so the dash blinked 88...the mark was made in the first of the two eights...it was the middle vertical line of the first eight...Does anyone know what this means or where I can find the codes.
Old Oct 7, 2010 | 02:13 PM
jdjohn84's Avatar
Do you mean the middle horizontal line? There's not a middle vertical line. Remember, think of the horizon when you think horizontal - side-to-side, not up-and-down.
Old Oct 8, 2010 | 10:23 AM
brad9101's Avatar
4th Gear
So if my air mix control motor has gone bad...Where is the best, meaning cheapest, place to get a new one? Anyone know how much they run? Thanks
Old Oct 8, 2010 | 12:25 PM
jdjohn84's Avatar
Here's a link to an online parts supplier (actually a dealership that sells online at lower prices).
http://www.acuraautomotiveparts.org/...s=&view=normal
Brad, you need #6.
MrLee, you need #5 (I would think).
Both are $100 each.
SidhuSaaB
May 30, 2020 12:40 AM
tsx_boy
Dec 13, 2019 08:33 PM
rcs86
Aug 2, 2016 06:52 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
hashbrown
Sep 29, 2015 12:13 PM
