Help! Check Engine Light and TCS light on.
Old Nov 1, 2012 | 03:51 PM
geedub's Avatar
Angry Help! Check Engine Light and TCS light on.
Check engine light and TCS light keep coming on after intake manifold cleaning. This is the second time I have done the intake manifold. The first time worked great but not this time.Can it be the EGR port? Do I need to take off the top and bottom of the intake to clean the EGR port? Please help my tabs expired and I need to pass emissions.
Old Nov 1, 2012 | 05:02 PM
01tl4tl's Avatar
do you mean you seafoamed the intake manifold vac port?
or you removed the intake manifold and partially cleaned egr?
need codes! parts stores will get them for you free,,cel will have codes
often after seafoam or similar if there was not enough heat generated in the after drive- the O2 sensor gets loaded up with crud and triggers a CEL
simply driving a few days will make it self clean and self clear the code
if your spark plugs are more than 100kmiles,,they are toast
if over 70kmiles on car- its time for remove intake manifold and clean egr system INSIDE the casting of the manifold,,not just the valve
Old Nov 1, 2012 | 05:03 PM
01tl4tl's Avatar
what happens when you remover the CLOCK fuse on passenger end of dash--then reinsert??
forces a full system ECU clear/reset all codes and start fresh
Old Nov 1, 2012 | 05:42 PM
3.2TLc's Avatar
Yeah, get the codes read......I'd question why the TCS light is on. The CEL may have nothing to do with the intake cleaning !
Old Nov 1, 2012 | 09:58 PM
geedub's Avatar
I did a complete removal of the intake and cleaned all the crap out to near new condition. I haven't read the codes and will do that.Also thanks for the tip on the clock fuse. Thanks for all the help.
Old Nov 1, 2012 | 11:31 PM
STONEColdAcurazineLegendZ's Avatar
Theres a button that controls the tcs I believe try that first, See what results you get when pushing it on and off. run it autozone and keep the codes handy to do some research.
Old Nov 2, 2012 | 11:01 AM
fsttyms1's Avatar
Pull the fuse and see if they go away. If not get them read and see what they are. The TCS light coming on with the CEL is Normal.
Old Nov 2, 2012 | 11:10 AM
01tl4tl's Avatar
its possible to invert/install UP side DOWN- the top cover gasket during egr cleaning
looks correct on base but blocks critical egr port on top section
thats where I would start if prob began after that work
always suspect/recheck last work done,,something left off, cracked/worn end on vac hose etc
electrical connector swapped???
the warning lights are just to get your attention
codes are clues to help find a diagnosis
Old Nov 2, 2012 | 11:14 AM
01tl4tl's Avatar
when you say the top and bottom of intake- do you mean the cover looking things as seen front and rear when looking at the engine?
those are the plenums- you can remove and clean in there too but not mandatory
For those who like to have the hood open at ziner meets--- those covers polish up really well -then leave the plastic engine cover off !
Old Nov 2, 2012 | 03:41 PM
geedub's Avatar
OK I got the codes read. The only code was PO325 knox sensor 1. So I bought one. Does anybody know where this senson is located?
Old Nov 2, 2012 | 11:27 PM
3.2TLc's Avatar
The knock sensor is located directly in the middle of the front of the motor, looking at it from the front of the car.
To test the sensor, reset the PCM removing fuse #13(clock BU), then start car and run motor at 3k rpm in park. Once the fan comes on, leave the motor run at idle for awhile, then run up to 3-4k rpm again for a few minutes.
Does the "CEL" code come back on ? If so, check for loose connections or a short in the wiring. Try this on the old sensor before you replace it ! May get lucky.
Old Nov 3, 2012 | 01:59 AM
geedub's Avatar
Thank You I will check it out in the morning.
Old Nov 3, 2012 | 03:21 PM
geedub's Avatar
I've checked my book and looked where you said. I cannot find the knock sensor. Is it under the intake manifold?
Old Nov 3, 2012 | 09:17 PM
3.2TLc's Avatar
Hey Geedub, yeah man....it's underneath. They don't make anything easy. I've heard of the wiring cable to this sensor being ate by mice !
Old Nov 4, 2012 | 01:19 PM
geedub's Avatar
I've read that too. I just found mouse crap on the intake cover. I would never have believed it.. but it looks like its for real. One more time removing the intake and I hope this will solve my problem.
Old Nov 22, 2012 | 09:10 AM
mrbustrbrown's Avatar
my tcs light came on after removal of my intake,went back over everything and noticed i forgot to plug something back in to the bottom of tb,plugged it back in and bam,light off
mada51589
Jan 9, 2025 04:40 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
