Help, 2003 TL not starting!
Old Jun 9, 2018 | 01:38 PM
Felix2's Avatar
6th Gear
I appreciate any help anyone can be. I have a 2003 Acura TL. Intermittently it won't start, turn the key and nothing. Dashlights come on and everything but doesn't start. Thought it was battery, got brand new battery, started...but then occasionally won't start or move out of gear.
After research, I found that if I removed the little plate on the gear console and pressed down the shift lock button it would crank.
Now, if it doesn't crank, I push down shift lock release....still won't crank. If I move it in and out of park, several gears then back to park....cranks. Sometimes.
Battery is good, brake depressed everytime I try to crank.
Any suggestions?
Old Jun 9, 2018 | 06:18 PM
Will Y.'s Avatar
Registered but harmless
Sounds like your starter is dying.
Hit the starter with a breaker bar the next time it doesn't crank. If it cranks then, it's the starter.
BTW, there is a subforum here specifically for the 2nd gen TL, too.
Old Jun 9, 2018 | 08:45 PM
ttribe's Avatar
MODERATOR NOTE: Thread moved to model-specific forum.
Felix2
Jun 9, 2018 11:34 AM
DejaVu85
Jul 17, 2010 04:24 AM
Chopsie
May 22, 2006 03:23 PM
bimmer88
Technology
48
Apr 21, 2006 10:41 PM
RaptorCLS
May 15, 2003 07:51 PM
