Heater and AC doesnt work
Old Nov 4, 2011 | 12:22 PM
juicyjuice815's Avatar
No change of temperature and blower doesnt blow when turned on.
Old Nov 4, 2011 | 04:58 PM
my.daily'tl''s Avatar
Always Working In
The infamous blower motor connection is burned. Requires new connector which a vendor here sells and possibly a new blower motor. Theres lots of threads on this.
Old Nov 8, 2011 | 03:00 PM
FireNation23's Avatar
Every porn dvd in a
It's a cheap piece, I had it replaced before, it was something around $5 not sure, but you gotta splice and connect about 10 wires if you DIY. If you listen to the dealer or whoever tells you what you'll have to replace, it might be around 100 but you don't need that whole wiring system, just the piece that is burned out.
Old Nov 8, 2011 | 05:12 PM
01tl4tl's Avatar
get the NEW UPDATED with longer wires --power connector for the blower, at acura $20
may also need a new resistor, located on blower motor mounting plate
visual under its shield will usually tell it fried
start with visual ck: under glovebox exterior edge- see the white connector- look at its underside too for blackening of connector,, or melted wires
Old Nov 8, 2011 | 05:13 PM
01tl4tl's Avatar
you did ck the cabin fan fuse right? if something else fails it may blow the fuse
mada51589
Jan 9, 2025 04:40 PM
acurajj
Sep 19, 2015 03:47 PM
EE4Life
Sep 11, 2015 10:13 PM
04tler
Sep 10, 2015 01:13 PM
ahsm
Sep 9, 2015 08:35 AM
