have a wierd missfire problem
Old Jan 9, 2010 | 07:05 PM
Rajca's Avatar
wham bam thank you ma'am
started happening monday. no sign or nothing. just happened one day and next day was all good. now it happens everyday only after work, not in the morning.
i feel the car misfire but not while in P or N. just in gear (moving or not) and when i go wot it doesnt misfire.
any suggestions? i seafoamed it through the vacuum line. only put in 91 octane. spark plugs? coil? but that would misfire all the time, right?
Old Jan 9, 2010 | 07:16 PM
juanclopez2786's Avatar
could be the coil doin that to you. ive seen that before. best way to diagnose it is to hook up a scanner with a misfire counter for each cylinder and have someone watch it while u put it in gear and see which cylinders giving you the problem so you can check out that cylinders plug and coil.
Old Jan 9, 2010 | 07:27 PM
Rajca's Avatar
my scanner showed misfire on all cylinder and a manufacture ignition problem or something like that.
Old Jan 9, 2010 | 07:31 PM
it shows each cylinder? if so were any a little higher than the others? try resetting it and monitoring it from startup and see what you get. watch for the first cylinder that shows up misfiring.
Old Jan 9, 2010 | 07:36 PM
Rajca's Avatar
its just a regular check engine scanner. i did reset it. no problems in the morning like always. but in the afternoon on the drive back is when it started to misfire.
Old Jan 9, 2010 | 07:46 PM
try switching coils from your cls to your tls. see if the problem is still there. at least you have another car to swap parts from to make diagnosing it easier.
Old Jan 9, 2010 | 08:14 PM
thinhthan's Avatar
im having the same problem.. i tried changing spark plugs swapping coils around and everything. i cant seem to figure it out
Old Jan 9, 2010 | 09:26 PM
nhn23's Avatar
I live in
how do you know if your car misfires?
Old Jan 9, 2010 | 09:35 PM
DimaB's Avatar
I am getting the missfires as well. I read somewhere about doing one coil at a time. Can someone refresh my brains as to what is suppose to happen after i pull one coil at a time. How do i know which coil is not working?
I am removing the bar that runs across the engine so that i can get to the back coils/plugs. do i need to remove some other thing thats sitting sort of on top of the middle coil?
Thanks,
Old Jan 9, 2010 | 09:39 PM
e30cabrio's Avatar
LFG RANGERS!!!!!!!!!!!
Will your scanner record? The way I finally figured out my TPS issue was by driving with the scanner in auto record mode. When the issue finally happened while the scanner was connected it started recording and grabbed it.
Old Jan 9, 2010 | 11:31 PM
Rajca's Avatar
the check engine light flashes when u are misfiring. im not gonna mess with my cl. i got a spare engine so ill grab the coils from that engine and put them in my tl tomorrow.
Old Jan 10, 2010 | 09:55 AM
twill220's Avatar
misfires???
everything was running smooth, then on friday i was just warming up the car letting it idle and the engine light came on. went to an auto store and was diagnosed as a misfire. just reolaced the sparks 3k miles ago...any ideas or suggestions to fix this
Old Jan 10, 2010 | 10:01 AM
Rajca's Avatar
^make a new thread. this is my problem and need some incite (sp?).
but are all ur spark plugs in snugly? did u drop a coil or two?
Old Jan 10, 2010 | 07:44 PM
thinhthan's Avatar
i got misfire but i dont got a blinking light i only got a check engine and the tcs light. i read in the service manual that if the engine light and the tcs light goes on thats a misfire and i hooked up a genusis to it and it says random misfire
Old Jan 10, 2010 | 08:00 PM
sbuswell's Avatar
I need 2 more gears
Could be a dual issue. If it gave you an ignition code it could be your ignition switch. The misfiring could also be a result of a camshaft or crankshaft position sensor as those can cause a shit ton of different problem including misfiring and overheating issues. I would do what you suggested and change out your coils and plugs since you have an extra engine at your disposal which kicks ass!!!
Old Jan 11, 2010 | 08:54 AM
02TL-S's Avatar
Burnt valve? Build up of carbon on top of piston or backs of valve?
I'm the original owner and use nothing but Mobil 1 synthetic and 91 octane since day 1..........I've been having the same issue for the last 4 months. At first I took it to a shop to diagnose. He showed me the tops of my pistons with a borescope? (full color screen, SnapOn). I couldn't believe it!!!! There was a huge shelf of carbon! I had him do a fuel injector cleaning, looked at it again. You could actually see where it had sprayed down and blew the center of the carbon away, but there was still a ton built up (kind of like when you take a garden hose and your spraying mud off a cement driveway, a ledge build up). SO I ended up changing all the coils and spark plugs, still misfired. I took it back and he checked every component on the engine (all the voltages for everything). Everything was fine, just this misfire crap. So I took the car home and did 3 cans of seafoam, that helped for about 3 months then light came back on. A week ago I took the top cover off of my intake and cleaned that (NASTY). Did Seafoam in the oil, gas tank, and intake, changed oil. Engine light has now been off for one week and car runs a little better. I can still tell there is a misfire. I have ordered all the top end gaskets, timing belt, water pump, (everything!) and I'm going to take the heads off and have them checked/rebuilt (couple months). I might have a bent valve from carbon build up or a burned up valve? I don't know but that's the path I'm going to take. While I have the heads off I can clean the tops of the pistons.
Old Jan 11, 2010 | 09:29 AM
Rajca's Avatar
Happened this moring. Driving to work all is good. Stop at a light and then give it gas and it starts misfiring, u can feel and hear it. Then whil cruising on the higway it start misfiring again. At random times for a few sec. Does it over and over again. But when I go wot it doesn't misfire. Also misfires while its parked.
Haven't done anything to the car. Gonna change the plugs today. And coils tomorrow
Old Jan 11, 2010 | 09:30 AM
Rajca's Avatar
Old Jan 11, 2010 | 07:42 PM
Rajca's Avatar
just swapped out all my coils and looked at the spark plugs. same codes as before. but, driving to the store it was misfiring like always, but back from the store with a can of seafoam in my tank (1/2 tank of gas). went to another store right by my car. then driving back home it didnt misfire at all.
this car is one problem after another. just gonna fix it and sell it. maybe buy 09 civic or smart car (yes smart car). 60mpg so id be spending less than $3 of gas a day and throw some crazy offset rims on their haha
Old Jan 12, 2010 | 06:10 PM
thinhthan's Avatar
with mines if i just rev it at a stop you cant tell theres a misfire unless your drive you could feel the car studder kinda
Old Jan 12, 2010 | 08:12 PM
Rajca's Avatar
my whole car shakes at idle now and most times on the highway u feel the steering wheel shake badly, then other times its like it had no misfire at all. im leaning towards fuel injectors or crank shaft sensor.
my car has been sitting in one place for a year, then put in a new trans and drove it, worked great for 3-4month and now this happens out of nowhere, didnt touch the car in those months either.
Old Jan 13, 2010 | 01:37 AM
thinhthan's Avatar
how hard is it to change the crack sensor?
Old Jan 13, 2010 | 04:20 AM
Rajca's Avatar
never done it before but i believe u have to take off the crank pulley and the timing cover thats down their and then change it. hope its that easy.
Old Jan 13, 2010 | 02:36 PM
thinhthan's Avatar
but im not even sure if its that is there a way to test it?
Old Jan 13, 2010 | 05:58 PM
Rajca's Avatar
dont know how to test it. but i have a spare engine that runs great so i know it will be good. only costs me some time
Old Jan 13, 2010 | 07:00 PM
sbuswell's Avatar
I need 2 more gears
Are you throwing a CEL? If so what are the codes?
Old Jan 13, 2010 | 07:53 PM
Rajca's Avatar
yup, 1-6 misfire, random misfire, manufacture ignition control malfunction every single time i clear the codes, the same ones pop back up
Old Jan 14, 2010 | 12:20 AM
thinhthan's Avatar
me to but my check engine doesnt blink
Old Jan 14, 2010 | 06:52 PM
sbuswell's Avatar
I need 2 more gears
have you changed out the coils and plugs yet from your other engine?
Old Jan 14, 2010 | 06:54 PM
Rajca's Avatar
changed the coils out. it seems like it get worse and worse as the days go by. plugs "looked" good (as if i didnt have a misfire).
been driving my cl-s6 the last two days . will work on the car this weekend
Old Jan 14, 2010 | 08:28 PM
05AcTL's Avatar
just sell that P.O.S already and get ur damn smart car!! lol
Old Jan 14, 2010 | 08:43 PM
Rajca's Avatar
lol. need to fix it first. then selling it.
Old Jan 14, 2010 | 09:21 PM
totaledTL's Avatar
Maybe it's a fuel injector in spite of code-
Old Jan 14, 2010 | 09:31 PM
Rajca's Avatar
that is good possibility. when i was doing my turbo build. one or two of the injectors had a cracked, um dont know what its called but a plastic like thing that over hangs a bit where the fuel squirts out, but it works great. and one injector would set off all those codes (or i think it wont), maybe just that one cylinder would be misfiring..
Old Jan 14, 2010 | 09:42 PM
fsttyms1's Avatar
If you have swapped out your coils and plugs and still have it odds are its either your fuel injectors or your ECU
Old Jan 14, 2010 | 09:52 PM
Rajca's Avatar
sounds more like fuel injectors bc when i go wot, all is good. so maybe a leaking injector, or a stuck open or closed injector until i go wot??
i dont have another ecu to swap. but ill check out the wires bc i had my neo hardwired into the harness. ill look at it later.
Old Jan 14, 2010 | 09:56 PM
fsttyms1's Avatar
swap out the injectors from the CL? Use Vaseline on the O rings so that they slide in without tearing. Or drive up here and ill loan you mine to try out. I have been needing an excuse to take my intake mani off to port match things.
Old Jan 14, 2010 | 10:19 PM
Rajca's Avatar
lol. i got a spare engine that im gonna take the injectors off. u still can take ur IM off to um, install the 09 tl sh awd manifold haha
Old Jan 14, 2010 | 10:26 PM
Rajca's Avatar
and kris, i dont want to drive my car that far with a really bad misfire.
Old Jan 15, 2010 | 01:12 PM
fsttyms1's Avatar
Um yea, that would require a few hundred extra dollars that i dont have to play with right now
