Ground location for headlights.
Old Jul 26, 2019 | 08:06 AM
DevinSidell's Avatar
Industrial Designer
My headlights have never worked right for years. Sometimes they would turn on fine on first startup, other times it would take a few key turns. Sometimes this would result in one being on or none at all. This was after they had just worked! I replaced the ballasts on both and I'm still having this intermittent problem.
Does anyone know where the ground is so I can fix this problem once and for all?
Old Jul 30, 2019 | 06:37 PM
Carlos Rios's Avatar
Same
I've got kind of the same problem so I didn't make a new thread. There's this little pigtail that pops out the side of the bulb igniters but I can't find where that connects to for the life of me.
Old Jul 30, 2019 | 11:03 PM
01acls's Avatar
If your marker lamps are on when you turn on your headlights then the grounds are good. Assuming your new ballasts are good then your ignitors are the problem.
The wire coming from the bulb goes to the ignitor and then to the ballast. The ballast is mounted to the bottom of the headlamp.
Old Jul 31, 2019 | 08:09 AM
Thus one
This little wire with a female connector.
The lights turn on all right but I don't like leaving loose wires.
Old Jul 31, 2019 | 08:46 AM
01acls's Avatar
That loose wire is not normal for a 2g TL from the U.S.A., I'm guessing it's probably for a JDM headlamp or anther country model of Honda/Acura.
The good news is you don't need that wire so don't worry about it. Just tie it to the black cable and make sure it doesn't short out some how, just in case it's hot.
Old Jul 31, 2019 | 08:30 PM
That does make sense since my TL is a Canadian model.
Old Nov 16, 2019 | 06:49 PM
molok0's Avatar
how did it go?
How did this end up working for you? Im about to do the same.. the ignitor I received has the external ground wire
Old Nov 16, 2019 | 07:02 PM
It worked fine
It worked perfectly without the pigtail connected. Didn't seem to need it.
Bull_in_a_china_shop
1G TSX Problems & Fixes
Dec 30, 2010 04:17 PM
bumpin
Aug 17, 2005 12:52 PM
AcuraX2
14
Apr 11, 2004 10:21 AM
