engine light on after oil change
Old Apr 16, 2010 | 12:05 PM
kpica's Avatar
4th Gear
Question engine light on after oil change
My husband changed my oil and after that the check engine light came on.He put to much oil in and drained it out,add new oil but the light is still on.Any suggetions on why it's on and how to turn it off?----Karen----
Old Apr 16, 2010 | 02:12 PM
swoosh's Avatar
takin care of Business in
its takes a while ~100 miles of driving for the ECU to get reset....
if you have the radio/navi code ready just unplug the battery for 15-20 minutes to reset the ecu !!!
there is another gas pedal way to reset it but i dont really know it on top of my head !!!
hope this helps....again after you add oil....start the car...let it warm up....take it on a flat surface....turn it off and check for the oil level on the dipstick....
let us know how it went !!!
Old Apr 17, 2010 | 01:09 AM
fsttyms1's Avatar
^ there is NO gas pedal method.
Just pull the clock Backup fuse to reset the ECU and turn the light off.
Old Apr 17, 2010 | 09:42 AM
jdjohn84's Avatar
2003 TL-S w/Navi NBP
Are you sure it's not the 'maintenance required' light intead of the 'engine light'?
Old Apr 17, 2010 | 05:27 PM
fsttyms1's Avatar
Good question.
Old Apr 17, 2010 | 10:46 PM
swoosh's Avatar
i thought csmeneance had a way to do so....well guess i was wrong
yup great point there john !!!
Good question.
Old Apr 18, 2010 | 11:15 AM
kpica's Avatar
4th Gear
Definately the check engine light.I'll try the unplug the battery method first to reset the ecu.See if that works.If not I'll pull the backup clock fuse and take it from there.Thanks gang,I'll let you know how it goes------------Karen------
Old Apr 18, 2010 | 04:11 PM
jdjohn84's Avatar
Tell him you'll change the oil yourself next time
Old Apr 18, 2010 | 05:59 PM
fsttyms1's Avatar
DONT unplug the battery. The Easiest way is to pull the fuse. That way you dont have to enter the radio code, and navi code if you have navi. The fuse method works just fine and takes less time.
Old Apr 18, 2010 | 06:00 PM
fsttyms1's Avatar
And there is NO reason the CEL should have come on after changing the oil. If it comes back on after resetting it have the codes read at a auto parts store.
Old Apr 18, 2010 | 06:22 PM
swoosh's Avatar
did he seafoam it before changing the oil....seafoam sometimes leads to CEL !!!
Old Apr 19, 2010 | 11:29 AM
kpica's Avatar
4th Gear
We (he) unplugged the battery and it worked!!!!You guys are geniuses.Thanks so much----------Karen-----
Old Apr 19, 2010 | 11:31 AM
swoosh's Avatar
Old Apr 19, 2010 | 12:05 PM
fsttyms1's Avatar
IF there is a Next time pull the fuse. IT will reset the light without having to go thru unhooking the battery and entering radio codes. Its much faster.
mada51589
Jan 9, 2025 04:40 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
