engine light on
Old Jul 15, 2010 | 09:49 PM
thekidandyou's Avatar
engine light on
The other day my engine light came on. Went to advance auto parts, had them run their little computer on there. It came back with a code reading : TCC googled it and it came back as 'tcc circuit malfunction' Help!!!!!!!!!!! what does that code mean!!!!.. sorry about the typing at work ..lol
Old Jul 15, 2010 | 09:50 PM
fsttyms1's Avatar
What was the actual code number
Old Jul 15, 2010 | 10:29 PM
smartypants's Avatar
Dude,
Get the actual code ! I checked the code list and here's all I could find with a TCC reference.
"P1887 TCC Release Switch Circuit (***(May not be applicable for Honda / Acura)***)"
Notice the note in brackets....
Get the code...
smartypants
Old Jul 16, 2010 | 09:11 AM
ok will have to go back and get it re done. There was no code number.
Old Jul 16, 2010 | 11:31 AM
01tl4tl's Avatar
there is always a code number- the car doesnt spit out actual info
remember codes are clues to the prob -not a real diagnosis in itself- as they are often misleading
Have to figure out why a certain combo is together and go from there
Old Jul 17, 2010 | 09:59 AM
the code P0740 and i forget to say that the TCS light came on the same time the engine light came on also
Old Jul 17, 2010 | 11:56 AM
01tl4tl's Avatar
hows the trans fluid smell on the dipstick? burnt?
any harshness or slipping when car shifts into 2nd and 3rd?
Old Jul 17, 2010 | 01:26 PM
fsttyms1's Avatar
Torque Converter Lockup Malfunction.
Unfortunately when that happens its usually time for a trans rebuild. You can try changing ALL the fluid by doing the drain fill procedure a bunch of times, and taking the solenoids out and cleaning them, rest the ECU and see if it comes back.
Old Jul 17, 2010 | 04:55 PM
dudeinaTL's Avatar
TCC is probably P0740. Your torque converter is probably burnt up...time for a new tranny. The clock is ticking. I went about 1.5k miles with P0740 before getting a rebuild. Other people have had failures much sooner.
Old Jul 17, 2010 | 07:29 PM
01tl4tl's Avatar
thanks guys- I didnt want to be the bearer of bad news~
Old Jul 18, 2010 | 07:44 AM
piggylover1985's Avatar
You're so nice :-). Anyway in this forum, i think many people had that same problem. So he won't be left out.
Old Jul 20, 2010 | 05:19 AM
Wow that sucks there. what does the TCS light have to do with it. Yes the tranny oil had a burnt smell to it As of yesterday my cousin that fix car's told me as he was driving the car as long as the TCS light is not it the car with shift gears once the light comes on it so slips
Old Jul 20, 2010 | 05:57 AM
Sorry guys. as long as the TCS light is not on. the car shift gear's fine, as soon as the light comes on that's when it starts to slip. DID a tranny drain and fill at a local acura dealer a couple of months ago. I should have went with the LS
Old Jul 20, 2010 | 10:05 AM
01tl4tl's Avatar
what year is your TL? and mileage?
not salvage/rebuilt title? usa car?
Amazing how often a higher mileage car goes to the dealer for a 3 qt trans fluid change and soon after-- the trans fails~
Washed out the crud holding the clutches together
If a reasonable age/miles you talk to the service MANAGER, explain you were just there for trans service and now you need some `Goodwill Assistance`
as it has predictably failed
Old Jul 22, 2010 | 07:47 PM
the car is a 2003 i got it at 126,000 and now it has 186,000 per as my cousin said the car shift fines but once the TCS light comes on.. she goes crazy
Old Jul 22, 2010 | 07:51 PM
usa car.. title is free and clear
Old Jul 22, 2010 | 09:09 PM
fsttyms1's Avatar
replace all the fluid, clean the solenoids and hope it works. If not you need a new trans.
Old Jul 25, 2010 | 08:40 PM
are the solenoids inside the tranny or outside the tranny
Old Jul 26, 2010 | 11:17 AM
01tl4tl's Avatar
https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
should be in the diy section--external selenoids
Old Jul 26, 2010 | 07:17 PM
there was nothing there about that
Old Jul 26, 2010 | 07:53 PM
01tl4tl's Avatar
look in gen3 diys- I know its on azine~
Old Jul 26, 2010 | 09:32 PM
fsttyms1's Avatar
They are taken out from the outside. Unbolt and remove.
Old Jul 27, 2010 | 02:54 AM
01tl4tl's Avatar
I think he needs a complete diy--
(sound of Alices restaurant playing in the background)
on 27, 8 by 10 color glossy photographs
with the circles and arrows pointin to the Offending parts, and a paragraph description on the back of each tellin of what they was looking at ~
gen3 has a great diy
Old Aug 6, 2010 | 10:08 PM
ugh thinking about getting rid of this freaking car..;((((((
Old Aug 6, 2010 | 10:33 PM
any know where I can get a good used tranny for this car. If not she will have to go
Old Aug 7, 2010 | 05:21 AM
01tl4tl's Avatar
good used acura trans..and a dash of miltary intelligence? I mean- those words dont go together!
probably not from a junkyard~when they sit they go bad
maybe from a trans rebuilder shop that has one built and ready to swap with you
or get yours redone
or in our private sales from someone doing a 6 speed swap
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
