Engine knock or fluttering?
Old Jan 30, 2016 | 01:54 PM
Joker222's Avatar
5th Gear
Hey guys this is my first post here because I really need some help on this.
Driving home last night all of a sudden my car lost a lot of power then I could hear a consistent knock that would speed up when I accelerated. Got home popped the hood, turns out I did have low oil, topped it off and started it again but, noise was still there and at idle. I recently changed my valve cover gasket and spark plugs about 60 miles ago before this started. So I decided to pull out the spark plugs, clean them up and RE torque them to spec. The gap I use is .43 and I torque them about 2/3 of a turn. But the noise is still there. I didn't have a chance to pull out the oil filter just yet but I do not have a drop in oil pressure at all. Not going to drive it anymore until the noise is gone. Also my mileage is at 200000
Old Jan 30, 2016 | 03:28 PM
MarcDavidoff's Avatar
Does the knock sound on the low side of the engine? It's hard to say over the Internet but if it ran low on oil hopefully it isn't a rod knock
Old Jan 30, 2016 | 03:45 PM
Joker222's Avatar
5th Gear
Can't really tell for sure but it's coming near the throttle body, haven't drove it since it started
Old Jan 30, 2016 | 03:47 PM
Joker222's Avatar
5th Gear
I did record a video... How do I post it up? New to this.... Lol
Old Jan 30, 2016 | 06:09 PM
fsttyms1's Avatar
When you say you were low on oil, How low were you? Like half a quart? 3 quarts?
Old Jan 31, 2016 | 12:34 AM
Joker222's Avatar
5th Gear
About 1 quart low.
My fuel is near empty also, don't know if that will help. Also no power steering
Old Feb 3, 2016 | 06:20 PM
ErickUa5's Avatar
Mr.Helpful Diagram
You can try unplugging one ignition coil at a time and listen for the noise level.(engine on)
If the noise is present on all cylinders then try removing the accessory belts then start the engine.
If its still there then you will need to go under the car, locate and remove the torque converter cover its only held on by 2 10mm bolts then you will see the flex plate, If it has play and you can reproduce the noise then it can be the flex plate bolts or the converter bolts that came loose. (engine off)
You should be a able to move the converter by hand if it has play or you can use a small crow bar to check.
Old Feb 3, 2016 | 07:04 PM
Joker222's Avatar
5th Gear
Thanks bro! I did do a compression test and all cylinders are good but it's a little high, 240 psi. I was thinking it was the flex plate, going to check it out tonight. When I tried driving it home I switch to manual shifting and it did had a hard time changing gears. It would just go from 2nd gear then quickly change to 3rd then 4th so that's why I was thinking I was losing a lot of power. Also the d5 light was blinking at the time but it stopped when I turned off the car and started it again. Will update you guys later. Thanks for the help
Old Feb 8, 2016 | 10:30 PM
musiclevelz5's Avatar
Sounds like it could be a bad coil to me.
Old Feb 10, 2016 | 11:07 AM
01tl4tl's Avatar
CODES we need codes!!!
Old Feb 11, 2016 | 03:14 PM
Chojun's Avatar
A blinking D5 light signals a problem with the transmission.
MikeRL
1G RL (1996-2004)
Oct 19, 2023 01:58 PM
Black Tire
Dec 18, 2017 08:15 AM
aIRpeACE
Jan 14, 2016 03:54 PM
DJMikeT
Jan 12, 2016 12:15 AM
DJMikeT
Jan 6, 2016 11:57 AM
