Electrical problems
Old Sep 21, 2018 | 09:41 AM
Shade Gaiven's Avatar
Electrical problems
Need help.
lost use of my turn signals and tail lights. Fuses are good. Wiring looks good but I'm not a specialist in electrical. Alldata shows the two circuits seem unrelated. Have brake lights, reverse, and headlights. Not sure what is going on with turn signal and tail. Hope someone here can help.
Old Sep 21, 2018 | 11:28 AM
front and rear? hows the cluster lights in the car itself.
Old Sep 21, 2018 | 11:31 AM
Front and rear. Everything in the cluster works except the turn signal indicators. Hazards are also non functioning if that matters. No hyper flash, nothing.
Old Sep 21, 2018 | 11:34 AM
Did you install LEDs in the turn signals or something? There's a fuse in the driver's kick panel that handle the tail lights, did you test the fuse or just visual inspection?
Old Sep 21, 2018 | 12:08 PM
I have not. And visual check. But both system are unrelated according to the schematic
Old Sep 21, 2018 | 12:59 PM
True but they both have fuses so that's the common denominator we're trying to rule out. Replace the fuses anyway to rule that out. Next would be checking the wire loom that runs along the the trunk lid. .
Old Sep 21, 2018 | 01:06 PM
Could a loom in the trunk affect the lights up front? Sorry, I know more about parts than I do electrical. Also, will have to rule that out for sure later. I may work in a garage now, but I cant pull in until after hours.
Old Sep 21, 2018 | 01:15 PM
That's mostly for the tail lights. Also the root cause for both is the MICU/fuse panel in the driver's kick, hence why i wanted you to replace the fuses just in case.
With both being out, I can't see why it WOULD be an issue with the wire loom.
jptsx12
1G TSX Problems & Fixes
15
Jan 2, 2010 11:31 PM
earthbound741
Apr 3, 2008 08:56 AM
NYCAcura2.5TL
1G TL Problems & Fixes
Jul 28, 2007 09:57 AM
robdog82
Oct 14, 2005 04:33 PM
clsman
Mar 24, 2001 11:16 AM
