Electrical Problem???
Old Jun 20, 2016 | 12:59 PM
jaaaydeeem's Avatar
Soooo I haven't found any related issues on the forums...
But as I was driving to work today, for some reason, my double din kept powering off/powering back on. When it did that, the maint. required light also flashed. It did this 4 times within like 10 minutes of driving.
Does anyone know what sorta electrical problem this may be???
*Double din is a Kenwood*
Old Jun 21, 2016 | 07:29 AM
fsttyms1's Avatar
Check your wiring to the radio to make sure nothing is loose or shorting out.
Old Jun 21, 2016 | 03:59 PM
jaaaydeeem's Avatar
Will do! Thanks.
Would a loose/shorting out of a wire from the radio would cause my maint light to flash on/off too?
Old Jun 22, 2016 | 06:57 AM
a short in electrical wiring will cause ANYTHING weird to happen.
its shorting out!! you've heard of the term electrical gremlins right? problems will just start to show up out of nowhere.
but thats not what fatty asked you to do! he asked for you to inspect to see if there are any loose wires. also, inspect the battery terminals. make sure they arent loose, corroded, disconnected, etc.
jo.deserres
1/2G MDX (2001-2013)
Jul 19, 2016 09:23 AM
Revolution245
2G CL Problems & Fixes
Jun 12, 2016 10:08 PM
Evilocity
Apr 22, 2016 09:33 AM
akruglick
Mar 13, 2016 07:36 PM
tiger2471
4G TL Problems & Fixes
Mar 1, 2016 08:39 PM
