Driver Window Stopped Working Help!!
Old Mar 21, 2011 | 08:36 PM
k20dream's Avatar
Wink Driver Window Stopped Working Help!!
so my boy and i traded cars for a week i have a 99 tl hes got the type s out of now where the driver window stoped working i checked the fuse looks fine the regualtor isnt making any noise when i press the buttons all other windows are working fine hes ppissed help me out sum one
Old Mar 21, 2011 | 09:18 PM
01tl4tl's Avatar
did you try a different fuse= looks good vs is good ~
switch? can you swap the connectors for the switches
Old Mar 21, 2011 | 10:25 PM
totaledTL's Avatar
Check the fuse with a meter.
Old Mar 22, 2011 | 11:36 AM
TLer trash's Avatar
With the key on, hold the window switch whichever way you want it to go, and whack the lower part of the door with a rubber mallet or your fist. This will buy you a little time if the brushes in the motor are stuck or almost worn out. Hit on the inside door panel or the underside of the door. You'll be hitting it hard enough that it would cause a dent if done on the outside.
Old Mar 22, 2011 | 06:52 PM
k20dream's Avatar
Question
well I changed the fuse car was off key out of igntion switched the fuse with a spare put a 15 in it and nothing happiend but the radio is now asking for a code I keep fuckin dudes car up help me man there no noise being made with the window seems like an electric problem what's the code anybody kno
Old Mar 22, 2011 | 08:38 PM
totaledTL's Avatar
Did you ever check the switch, as suggested? Use a meter on that too if possible.
What abt. suggestion in post #4? We need feedback-
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
acurajj
Sep 19, 2015 03:47 PM
theinsvnity
Sep 10, 2015 10:22 PM
ahsm
Sep 9, 2015 08:35 AM
dlknight
Sep 3, 2015 07:54 PM
